Should I use longer header bolts with aluminum heads?
#2618802
02/08/19 06:46 PM
02/08/19 06:46 PM
Posts: 1,074 So Cal, USA
Fab64
So Cal, USA
Hi all,
The new 440 I've just built has Edelbrock aluminum heads. The headers bolts I was using in my old cast iron heads are from tti, and are 1" long. With the lock washer, that leaves about 7/8" of thread. The header flange and gasket take up about 7/16", so that leaves only about 7/16" thread going into the head.
I've measured the depth of the holes in the new heads, and they're about 1-1/4" from the surface of the header flange (or 13/16" deep from the head surface). So, I could easily go up to 1/2" deeper with my bolts, and not bottom out. That would be 1-1/4" to 1-1/2" header bolts.
Should I go longer, or are my current bolts sufficient? Thanks for any advice.
Roger
Re: Should I use longer header bolts with aluminum heads?
[Re: lewtot184]
#2618816
02/08/19 07:29 PM
02/08/19 07:29 PM
Posts: 43,267 Bend,OR USA
Cab_Burge
[Re: Fab64]
#2618824
02/08/19 07:53 PM
02/08/19 07:53 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
From Edelbrock Top-quality features include threaded inserts in rocker stud and exhaust bolt holes for superior strength and durability I wouldn't worry about it.
[Re: Fab64]
#2619021
02/09/19 12:59 PM
02/09/19 12:59 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Two things to think about. I always use Remflex gaskets on my Mopars these days. I've had great success with them and their collector gaskets are reusable 90% of the time. They also only require a relatively low amount of torque to tighten, although I do re-torque them until they hold without needing further re-torqueing.
Second, use a good quality anti-seize on your bolts and wipe them lightly with a cloth after application to remove the excess. Aluminum is susceptible to galling, especially if you use stainless steel fasteners, with also always require anti-seize on them to avoid galling.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2619024
02/09/19 01:06 PM
02/09/19 01:06 PM
Supercuda
About to go away
About to go away
up yours
The heads have helicoils in the exhaust bolt holes. Stainless steel helicoils. You are not screwing your stainless fasteners into aluminum.
[Re: Fab64]
#2619205
02/09/19 09:57 PM
02/09/19 09:57 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
I would use studs and not bolts
[Re: moparx]
#2619615
02/11/19 12:29 AM
02/11/19 12:29 AM
Posts: 6,497 N.E. Ohio
KillerBee
N.E. Ohio
I've used the Mr. Gasket 3415 header studs on a few engines now with good results. Both steel and aluminum heads.
They have two thread sizes on the stud with a smaller 5/16 thread sticking out to make header installation and nut clearance much easier. I usually buy better grade 8 nuts to replace the ones included with the studs. I don't believe they are currently being made/sold new but they do show up occasionally on e-bay.
[Re: moparx]
#2619868
02/11/19 04:16 PM
02/11/19 04:16 PM
Posts: 637 SoMd, USA
135sohc
SoMd, USA
I would use studs and not bolts my preference as well. i believe ARP makes 12 point nuts with a small head size if you need them. much easier to get nuts started on studs in tight bends than bolts [relatively speaking]. They do, they were easy to find but of course when I went to order no body had them in stock. Used all ARP stuff when putting the manifolds back on my 2.2, spendy but much less frustration using all reduced head size hardware.
[Re: Supercuda]
#2620236
02/12/19 01:01 PM
02/12/19 01:01 PM
jbc426
West Coast, USA
The heads have helicoils in the exhaust bolt holes. Stainless steel helicoils. You are not screwing your stainless fasteners into aluminum. Ah, even more important to use anti-seize on the bolts then. Stainless steel into stainless steel is generally prone to galling.
[Re: jbc426]
#2620281
02/12/19 03:07 PM
02/12/19 03:07 PM
Posts: 20,201 Park Forest, IL
slantzilla
Park Forest, IL
As someone who is forced to work with stainless fasteners, these are very wise words. I've had stainless nuts gall on stainless bolts threading them together by hand.
[Re: slantzilla]
#2620777
02/13/19 02:27 PM
02/13/19 02:27 PM
Posts: 19,555 north of coder
moparx
As someone who is forced to work with stainless fasteners, these are very wise words. I've had stainless nuts gall on stainless bolts threading them together by hand. absolutely been there, done that [many times,-you would think i would learn not to even try by hand without anti-seize !], got a t-shirt AND a sticker ! anti-seize is your friend with stainless !
[Re: Fab64]
#2623150
02/19/19 12:40 AM
02/19/19 12:40 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
One thing to add here is headers also hold up most of the exhaust system. The engine moves around and most of our exhaust systems does not want to twist with the engine, loading the header bolts.
