Re: steering hitting pan, b body [Re: 70moparmike] #2622915
02/18/19 02:36 PM
02/18/19 02:36 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Looks like its down to three options; hammer in clearance to the pan, modify engine location within the engine bay through motors mounts or mounting pad relocation, finally, swap steering parts until you find a compatible combination of dimensions.
Re: steering hitting pan, b body [Re: TC@HP2] #2635736
03/22/19 11:07 PM
03/22/19 11:07 PM
n.c.
geo. Offline
geo.  Offline
n.c.
Originally Posted by TC@HP2
Alignment of the steering linkage itself could also be a factor. I have found numerous Mopars over the years that had shims behind the steering box where it bolts to the K. You can alter the plane the linkage operates in by shimming the box to move this plane up or down. There also is the possibility of idler arm and its bushings not duplicating factory position, or the bushing is worn/bad and allow unwanted motion, or its specific mounting location is just slightly off. Or, in the case of ultimate tolerance stack up, a little bit of everything above is off, just a hair, but add them all together and now something hits.
Personally, I'd much rather install a 1/4" shim into an motor mount or try moving some other pieces of the puzzle around to create the necessary clearance before I'd hammer on a $400 oil pan.
Don't shim or remove shims from steering box without checking bump steer, this will change things.
One of the gm suspension gurus used to reccommend limiting steering travel on road race f bodies.
He pointed out that for track use giving up a little travel was worth gaining oil pan, header, and tire/fender clearance.
I think he welded stops to the crossmember, might be a way to do this on your car.
Re: steering hitting pan, b body [Re: 70moparmike] #2652863
05/07/19 08:33 AM
05/07/19 08:33 AM
indy
70moparmike Offline OP
indy
found a answer. can someone tell me if it will hurt to use the quick ratio idler arm and not use the pitman arm with it? i measured the distance out from the hole in the frame and the idler is about a inch and a half farther out that the stock one. but the drivers side quick ratio is almost two and a half father than stock. if i used it too. but terrible interferance with the headers on drivers side. steering rod looks straight in line for steering rods from ball joints across to the other ball joint. it clears the tti headers too! someone please tell me if it will hurt on the alignment end of it. thanks moparts!!!
Re: steering hitting pan, b body [Re: 70moparmike] #2653441
05/08/19 04:11 PM
05/08/19 04:11 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
I'm not sure why but I know your suppose to match both - fast ratio idler and pitman, or stock idler/pitman
Re: steering hitting pan, b body [Re: dangina] #2653455
05/08/19 04:55 PM
05/08/19 04:55 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The AAR and T/A didn't match. the theory is that matching length's ensures consistent ratio in both directions. The E bodies had clearance issues and the engineers found that using the shorter idler made the needed clearance and the change in L vs R ratio was small enough not to matter.
Using the shorter pitman arm eliminates any benefit of a faster ratio.
Don't be the exception.
Re: steering hitting pan, b body [Re: Supercuda] #2653463
05/08/19 05:22 PM
05/08/19 05:22 PM
Colorado front range
BcudaChris Offline
BcudaChris  Offline
I run the fast ratio pitman/stock idler setup, only because header massage would have been required to fit the longer idler.
I only notice anything during parking maneuvers (foreword or reverse) starting with the wheel ~1/16/turn from the lock in either direction. It seems to come around quicker, particularly turned almost all the way left in reverse.
I can't imagine it being a problem, even on a tight autox. That said, I haven't done an autox since installing the setup.
This is in an E body
Re: steering hitting pan, b body [Re: BcudaChris] #2653577
05/09/19 05:43 AM
05/09/19 05:43 AM
indy
indy
i have the opposite problem. the pitman would require alot of header massaging and the longer quick ratio idler arm clears barely. guess i should be ok using the set up to clear my pan easily. might be an answer for all you others with the same problem. thanks moparts
Re: steering hitting pan, b body [Re: Supercuda] #2653674
05/09/19 11:44 AM
05/09/19 11:44 AM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Supercuda -- "The E bodies had clearance issues and the engineers found that using the shorter idler made the needed clearance and the change in L vs R ratio was small enough not to matter."
I find that hard to believe as there are no "clearance issues" with a factory setup, nor with the longer idler arm with a factory exhaust. I personally spoke with Chrysler engineers about this matter in the mid-70s.. They knew about it right away, but by the time it could be corrected by having to change the standard short factory idler arm to the longer and correct C-Body idler arm, whenever the Fast-Ratio power steering box was optioned for the car, it was too late in the production runs... and the overall cost factor was an issue. Furthermore, not that many cars were being ordered with the "Fast-Ratio ps option". The writing was already on the wall to kill the AAR/T/A and the Fast-Ratio ps option -- even for the early 71 E-bodies having that option made available... which hardly anyone, including the dealers, knew about. So, it was decided to move on and leave it alone... marketing the ps option as "Fast-Ratio" was cool and attractive, and needed at that time; too bad they screwed up. Bottom line: It would've been too costly to make that needed production line change.
Shame on MaMopar for ignoring the matter.
Also, remember, no-one "created" or "developed" what has become known and referred to as the "fast-ratio idler arm"... it is simply a ~70 C-body idler arm.
Re: steering hitting pan, b body [Re: Mopar Mitch] #2653698
05/09/19 01:13 PM
05/09/19 01:13 PM
indy
indy
does the c body arm hang down any lower? it would clear my headers if id does? but if same arm, no good will happen for me on the arm situation?
