Power guess #2618033
02/06/19 11:22 PM
02/06/19 11:22 PM
Western New York
sixpackbee Offline OP
Western New York
572, slightly massaged Stage V heads, Bullet solid roller 266/268@50, 686/661 ground 110, 11 to 1, 950 Quick fuels. Probably dyno with C12. Is a pump gas street engine. Used to doing Stock/SuperStock type stuff or restoration engines so I do not know what to expect. Any guesses?
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: Power guess [Re: sixpackbee] #2618050
02/06/19 11:53 PM
02/06/19 11:53 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
I would dyno it on the fuel you are going to run. Why spend all the time tuning it and then put different fuel in? My geuss is around 700 for hp and 660 for tq.
Re: Power guess [Re: sixpackbee] #2618078
02/07/19 01:02 AM
02/07/19 01:02 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I think it will be square with the cam numbers 680hp, 660 torque. Should run real good and be ultra reliable! up
Re: Power guess [Re: sixpackbee] #2618091
02/07/19 01:29 AM
02/07/19 01:29 AM
I built and dyno tested a pump gas 572 C.I. Hemiroid motor last year that has dual 4150 dry EFI throttle bodies(1150 CFM each) on a in line dual four Stage V single plane intake, CNC ported Stage V heads and a smaller solid roller cam.
It made the best HP at 6500 RPM ending up with 799 HP, best torque on a different pull730 Ft. Lbs. at 4900 RPM on CA 92 octane pump swill in Chico, CA shruggy
I was expecting more HP and torque but these are the numbers from the dyno whiney
I had Rich from Fastman EFI do the EFI tuning, we tried both open loop and close loop and several different total timing settings. We did the best we could but did not want to wear it out chasing numbers down
it is going into a 1971 Challenger street and local show car, built for comfort and impressions, not a racer at all whiney
Unless I get to drive it devil whistling boogie
Flog that puppy until it squeals with delight whistling
Re: Power guess [Re: sixpackbee] #2618260
02/07/19 02:15 PM
02/07/19 02:15 PM
gregsdart Offline
gregsdart  Offline
I'm with cab, i think 800 hp will be about it, but good torque lower than expected.
Re: Power guess [Re: gregsdart] #2618273
02/07/19 02:40 PM
02/07/19 02:40 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
1 million horsepower.. luck. Cool build keep us informed on the progress
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
