Page 3 of 4 1 2 3 4
Re: New Best with the Flying Toilet Injection #261731
03/23/09 09:45 AM
03/23/09 09:45 AM
Swamps of South Jersey.
W
wildcargo Offline
wildcargo  Offline
W
WOW MOM WOW . Jim you just keep getting faster way to go.
Bud www.wildcar-go.itgo.com
64 DODGE
60' 1.433,
1/8 6.38 at 107.4,
1/4 10.08 at 132.02
foot brake, leaf springs
Re: New Best with the Flying Toilet Injection [Re: wildcargo] #261732
03/23/09 09:47 AM
03/23/09 09:47 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
Congrats Jim! That's awesome! CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: New Best with the Flying Toilet Injection [Re: an8sec70cuda] #261733
03/23/09 12:09 PM
03/23/09 12:09 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
Congrats Jim, what size valves are in the heads?
Re: New Best with the Flying Toilet Injection [Re: 440Jim] #261734
03/23/09 12:28 PM
03/23/09 12:28 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Great numbers...WOW gotta love that air too. Sounds like the car is working well to. We were in 3000-4400' of air this weekend in Vegas.
What kind of DA do you typically see in the summer months? Be curious to see how well it runs then, always heard the alky rule about the DA swings. Just never run the stuff to see. Be interested to see what you come up with.
Re: New Best with the Flying Toilet Injection [Re: 440Jim] #261735
03/23/09 12:51 PM
03/23/09 12:51 PM
gregsdart Offline
gregsdart  Offline
Hey a big congrats on a very successful first outing! Thats rockin, man!
Ever thought of trying some M5 methonal from Vp? Supposed to be worth .05 or so. that coupled with radial drag slicks and a spot on tune, with the ladderbars up a hole just might put it into the 8s!!
I know you bracket race, but thought you just "might" want to try this stuff for braggin rights, although you have plenty to brag about as is!
Re: New Best with the Flying Toilet Injection [Re: gregsdart] #261736
03/23/09 04:07 PM
03/23/09 04:07 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Thats really impressive for your first time out with the toilet.
Stiffer shocks or limiters on the front????
Im sure less wheelstand would equal more ET.... But i know you like the traction that the wheelsup launches provide for consitancy.
But WOW that is really flying
Re: New Best with the Flying Toilet Injection [Re: 340RICK] #261737
03/23/09 06:11 PM
03/23/09 06:11 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I found that plug gap was very sensitive in the alky injected Rons toilet setup, just some food for thought.
I made more than one change at a time, cause I knew they would both be in the right direction. One was a new set of plugs that I gaped kinda wide like .048-.050. The car slowed down from a 4.90 in the heat to 4.93-4.94 It took me awhile to figure it out too.
My ignition system was probably border line to began with, being a large engine with lots of compression 15:1+ the 6AL must not have had the oomph for that many rpms. 7400+
Anyways, gaped the plugs back down to mid .030 and the e/t responded
Re: New Best with the Flying Toilet Injection [Re: Bob_Coomer] #261738
03/23/09 09:16 PM
03/23/09 09:16 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Re: New Best with the Flying Toilet Injection [Re: BradH] #261739
03/23/09 09:24 PM
03/23/09 09:24 PM
Saskatchewan, Canada
cudabin Offline
cudabin  Offline
Hey Jim,
I am no expert, but according to Monte Smith, on a ladder bar car you stiffen the rear shock extension to reduce wheelies...
Perhaps the increased torque from the Alcohol will allow a higher ladder bar setting and still hit the tires enough to hook?
Also you might raise the air pressure 1/4 to 1/2 a pound and see if you can get a "little slippage" or wheel speed as they call it?
Interesting that you ran 30 degrees. Ron's manaul says to increase timing vs. gas.
Please post again when you try the 34 degrees.
Cheers,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: New Best with the Flying Toilet Injection [Re: 340RICK] #261740
03/23/09 09:27 PM
03/23/09 09:27 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
That Jim does his homework before he makes a change. Congrats Jim, I think your the Flat tappet King of ET around here. mike
Re: New Best with the Flying Toilet Injection [Re: Sport440] #261741
03/23/09 10:23 PM
03/23/09 10:23 PM
Idaho
Runner Offline
Runner  Offline
Idaho
it would be really cool to see the car get into the 8s n/a with a flat tappet cam.
Re: New Best with the Flying Toilet Injection [Re: MRMOPAR622] #261742
03/23/09 10:50 PM
03/23/09 10:50 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Simply amazing Jim.
Re: New Best with the Flying Toilet Injection [Re: Runner] #261743
03/24/09 01:30 AM
03/24/09 01:30 AM
AndyF Offline
AndyF  Offline
I agree. 8 secs with a flat tappet door slammer is way cool. Need to get that car in one of the mags.
Re: New Best with the Flying Toilet Injection [Re: AndyF] #261744
03/24/09 10:02 AM
03/24/09 10:02 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Way cool, Jim
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: New Best with the Flying Toilet Injection [Re: cudabunch] #261745
03/24/09 07:41 PM
03/24/09 07:41 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
These heads have 2.25" intake valves, but the porting is just middle of the road, nothing outstanding in the mid lifts.
Al,
In the summer we often get 2500 ft DA, with lots of humidity. The track is at 80 ft elevation, so if the sun is shineing on a 50 degree spring day with high pressure...
Rick,
I put double the front end travel limiter in to try and stop the excessive wheel stand, but it was not enough. I will increase the damping on the front shocks, add more travel limiting and see what else I can come up with (my fiberglass trunk lid would get 25 lbs off the back). And in warmer weather it should calm down some too. And if I have to move the ladder bar front mount up, I will (but it hurts the tire sidewall life).
Rapid Transit,
Thanks for the tip. I have always run 0.035" spark plug gap with my MSD digital 6 and coil. I don't believe in the big gaps. I did put new plug wires and distributor cap on for this year. I was running last year's Autolite AR3933 plugs that had 23 runs on them. I have a new set of NGK R5671A-9 ready to go.
cudabin:
Thanks, I will give that a try, they are single adjustable. And I remember years ago I softened them to improve hook (weight transfer?) with the smaller engine. I started at 30 degree ignition timing just to be safe not knowing if the initial tune was lean.
540Dust has a Duster with a 540 engine running the Comp 324/0.650" cam running my ETs. I forget the exact number and his weight.
Re: New Best with the Flying Toilet Injection [Re: 440Jim] #261746
03/24/09 09:33 PM
03/24/09 09:33 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
2770 lb car 220lb driver Back halved 4-link Al low deck block.
Re: New Best with the Flying Toilet Injection [Re: 540dust] #261747
03/24/09 10:39 PM
03/24/09 10:39 PM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
Jim, That is awesome. Good job.
I might pm you when I get ready to install mine. I just bought a used unit, less pump and drive assembly. Do you know the ratio between the pump and crank?
I doubt I install it this year as I am going to be sorting out too many new items as it is and have spent enough money already. LOL Beep
Re: New Best with the Flying Toilet Injection [Re: Bigbeep] #261748
03/24/09 10:47 PM
03/24/09 10:47 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Nice Job, Jim. You are very consistent at going faster every single year. So close to an 8 second pass, and with a flat tappet cam to boot. Very impressive.
2 kids and a dog
Re: New Best with the Flying Toilet Injection [Re: TonyS451] #261749
03/25/09 12:12 PM
03/25/09 12:12 PM
Peoples republic of clackamas ...
atoetly Offline
atoetly  Offline
Jim I have been trying to chase your ets with similar combos and of course the flat tappet cams and can't even come close. Very impressive.
Re: New Best with the Flying Toilet Injection [Re: atoetly] #261750
03/25/09 08:10 PM
03/25/09 08:10 PM
Petersburg, Va
Darrell Offline
Darrell  Offline
Petersburg, Va
Dang Jim, I've always told other racers-spectaters your combo with your ET&MPH and they looked at me like I had 2 heads! What am I going to tell them now?
Great Job!
Page 3 of 4 1 2 3 4
