60 series vs 70 series Goodyear Polyglas tires #2616981
02/04/19 07:12 PM
02/04/19 07:12 PM
Bradford, Ontario
Barrelhouse Offline OP
Bradford, Ontario
What's the difference between the 60s and 70s tires ?, is it the over all tire width ,tread width , or height ?.
Re: 60 series vs 70 series Goodyear Polyglas tires [Re: Barrelhouse] #2616984
02/04/19 07:18 PM
02/04/19 07:18 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
60 series is sidewall is 60% of the tread width, same with 70%. Same as modern tires.
Re: 60 series vs 70 series Goodyear Polyglas tires [Re: Barrelhouse] #2616998
02/04/19 07:47 PM
02/04/19 07:47 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
It's called "aspect ratio"; the ratio of sidewall height to tread width, as described above.
Re: 60 series vs 70 series Goodyear Polyglas tires [Re: topside] #2617010
02/04/19 08:23 PM
02/04/19 08:23 PM
dogdays Offline
dogdays  Offline
The shorter sidewall cuts tire flex on turning. I seem to remember the 70s on performance cars on 14s and the super performance cars got 60 series tires on 15s.
R.
Re: 60 series vs 70 series Goodyear Polyglas tires [Re: Barrelhouse] #2617030
02/04/19 09:15 PM
02/04/19 09:15 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
According to the chart I just googled, a G60 15 has a diameter of 26.46" and a G70 15 has a diameter of 27.46". Different letter sizes have different height differences, and then you need to take in the wheel diameter that also changes the differences. As I remember from back in the day, an F70 14 had about the same height as a G60 15, but that was a long time ago. Gene
Re: 60 series vs 70 series Goodyear Polyglas tires [Re: poorboy] #2617315
02/05/19 02:45 PM
02/05/19 02:45 PM
moparx Offline
moparx  Offline
the only thing wrong with using published dimensions, is the difference between tire manufacturers of a particular size can vary up to an inch.
i have witnessed and measured this countless times over the years.
also, keep in mind the difference between a "loaded" dimension vs an "unloaded" one.
beer
