Re: Cam/Lifter Install - Clairification on Gear Set Uo
[Re: buildanother]
#261680
03/22/09 11:36 AM
03/22/09 11:36 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
It is easiest lining up dots with crank at 12 oclock and cam dot at 6 oclock, BUT that is set to fire cyl #6. When both dots are at 12 oclock, then it can be set up to fire cyl #1.
Correct!! As long as you set the distributor to either fire # 6 without the engine turning or turn the engine over one crankshaft rotation so it's at TDC #1 before you drop the distributor in all is good..
[Re: 1_WILD_RT]
#261681
03/22/09 11:48 AM
03/22/09 11:48 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Most of the time the cam/crankshaft installation position means nothing after the cam is installed as for the firing position of the number 1 piston. Yes installed at 12/6 places number 6 in the firing position but most engines after the cam is installed have the crankshaft rotated from that position for one reason or another so the position at cam installation is rather insignificant after the gears and chain are installed whether dot to dot or degreed. I have yet to see one that isn't rotated after the installation of the cam and before firing. Always check the TDC firing position of the number one piston before instillation of the intermediate gear and distributor.
[Re: Dodgem]
#261683
03/22/09 03:43 PM
03/22/09 03:43 PM
RapidRobert
With the dots at 6 o'clock & 12 o'clock #6cyl is at TDC compression ready to fire. 12 o'clock & 12 o'clock #1 cyl is at TDC compression & ready to fire. It's confusing because the pics in shop manuals show 6 o'clock & 12 o'clock which would lead a person to believe that Ok you R&R your timing set, line the dots up like shown & you're ready to time the dist to #1 . 6o'clock & 12 o'clock are closer than 12 & 12 & easier to line up either visually or with a straight edge but WHY the manuals neglect to inform you that you are on #6 tdc compression or else that you then need to rotate it (1) revolution is beyond me. Your last sentence, when you tore it down & had it at 12 & 6 the rotor would have had to have been pointed at wherever you had the #6 plug wire on the cap
