Page 3 of 3 1 2 3
Re: New video testing new converter [Re: 340Cuda] #2615958
02/02/19 02:06 PM
02/02/19 02:06 PM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
Originally Posted By 340Cuda
Shiloh,
I have heard seven inch converters can be very hard on the engines thrust bearing and that if you let off and get back on one at the finish line they sort of "unhook" and you lose propulsion.
Has that been your experience?
Thank you for sharing your experience with us.
Bill
. Bill honestly I can't say that I have experienced that issue it does sound plausible I honestly feel that a 7 inch converter is going to be the fastest way down the track that being said they have had a harder time nailing it down probably because of the two speed and the weight of the vehicle.. pulling it out and sending it back for a tune-up constantly becomes a headache.. the other problem that we have had with the seven inch converter is overheating the converter in one pass it will completely burn all the paint off the converter.. even after it being tuned up giving the Builder racepak information.. I bet a 3-speed with a perfect 7 inch converter would be scary fast... there are others on this board that have more experience with a 7-inch converter than me maybe they will chime in on the count of I'm kind of curious about your question as well Bill..
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: New video testing new converter [Re: WHITEDART] #2615996
02/02/19 02:57 PM
02/02/19 02:57 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
That is definitely making things happen.
Very nice !
Re: New video testing new converter [Re: WHITEDART] #2615998
02/02/19 02:59 PM
02/02/19 02:59 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I do run a three speed R3/W9 in a 3,180 lbs car. I have been told I need a 7" 7,000 stall converter by folks that should know.
Right now I am running an 8" that flashes to 6,000 or so.
I have to run a single 750 CFM carb and it does want to run at the RPM level you are at, at least so far. Getting ready to dyno a new cam so maybe that will change.
I am still in a development mode and trying to learn from others.
Again thanks for sharing information with us and I look forward to hearing more down the road.
Bill
Re: New video testing new converter [Re: WHITEDART] #2616013
02/02/19 03:53 PM
02/02/19 03:53 PM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
small blocks always out run big blocks,only cars run that fast is chevys at my track,but theres only 2 mopars that run at my track
Re: New video testing new converter [Re: dart games] #2616074
02/02/19 06:13 PM
02/02/19 06:13 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
What in the he!! Are you talking about ?
....BAD A$$ STREET CAR.....
Re: New video testing new converter [Re: WHITEDART] #2616104
02/02/19 07:22 PM
02/02/19 07:22 PM
CEDAR RAPIDS
Plymouth340 Offline
Plymouth340  Offline
CEDAR RAPIDS
I just recently put a 7in converter in my W7 headed 394 small block. Trans temperature didn't seem to change from the 8in. RPM falls back to 7500 on the shift. And the car really liked it. picked up almost two tenths in the quarter mile. Its a 727 torqueflite.. Only have about 15 runs on it so far
Re: New video testing new converter [Re: WHITEDART] #2616149
02/02/19 08:19 PM
02/02/19 08:19 PM
San Diego, CA
mopar_man619 Offline
San Diego, CA
she rollin !!!! sherman's never gonna make it off the dyno now laugh
1967 Plymouth Valiant Gen III Hemi
11.42@119
youtube.com/moparman619
Re: New video testing new converter [Re: Plymouth340] #2616426
02/03/19 02:17 PM
02/03/19 02:17 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Sounds like you got a good one! Who built it?
Re: New video testing new converter [Re: 340Cuda] #2616435
02/03/19 02:47 PM
02/03/19 02:47 PM
CEDAR RAPIDS
Plymouth340 Offline
Plymouth340  Offline
CEDAR RAPIDS
A-1
Re: New video testing new converter [Re: Plymouth340] #2616450
02/03/19 03:21 PM
02/03/19 03:21 PM
bean town ....Ca
W
W
bean town ....Ca
. Very impressive hot rod can you put it on a 29-10.5. And bring it out to muscle cars at the strip for the Mopar small Tire shootout.. we still need more cars
Re: New video testing new converter [Re: WHITEDART] #2616498
02/03/19 05:16 PM
02/03/19 05:16 PM
CEDAR RAPIDS
Plymouth340 Offline
Plymouth340  Offline
CEDAR RAPIDS
that would be fun but I'm in iowa so probably not..
Re: New video testing new converter . Updated [Re: WHITEDART] #2616504
02/03/19 05:26 PM
02/03/19 05:26 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
eek up
72 Plymouth Roadrunner 11.08@123.25
Re: New video testing new converter . Updated [Re: WHITEDART] #2616509
02/03/19 05:38 PM
02/03/19 05:38 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Shift at 8800 you want to get that fallback on the shift to be 80-8100 or a tad more. Some of that will be found in power numbers and tuning but IMO its still pretty tight.
FWIW we run a billet 7" in the Vette. Shift 1-2 is earlier than 2-3. 1-2 is typically 95-9700 and 2-3 is usually 97-9900 with the "old combo". We typically see a 500 rpm drop on 1-2 and a 700 on 2-3. Still not perfectly happy with it and have now gone to a lockup deal. This is with a ProFlite behind the SB.
FWIW never seen any issues with the thrust on a 7 converter. We have run one in the red car for a few years, and I have run one for a few years before that with the 99.
Here is a pic of a racepack log from an 1/8 mile pass of 5.10 just for comparison sake. Clearly the tuneup was off a bit on this pass as well. 60- was only 1.15
Re: New video testing new converter [Re: WHITEDART] #2616554
02/03/19 07:04 PM
02/03/19 07:04 PM
CEDAR RAPIDS
Plymouth340 Offline
Plymouth340  Offline
CEDAR RAPIDS
. I took out a 7in converter that would flash to 7300 . And drop to 7500 on the gear change.. this converter felt very mushy and the efficiency was not very good however it was fast.. it went a 119.2 /60 ft...with a 5.42. At 126mph . And would pick up another 33 mph on the back half.. at about 15% slippage.. I had an 8-inch built looking for a little more torque multiplication and a little more efficiency. It is slightly tighter at about 7100 rmp. I think it needs to be at about 7,500.. that being said it's still went its new best at 5.39 at 127.. we still had some ET left in the tune-up unfortunately the track wasn't up to the task also if you noticed it was smoking pretty heavily.. it was pulling in a . Hefty amount of oil into the intake track my fault I got that squared away now hopefully we can get it to a good track and get the car to run what Wallace says it should run..
what is your RPM at the finish line??
Re: New video testing new converter [Re: Plymouth340] #2616560
02/03/19 07:17 PM
02/03/19 07:17 PM
bean town ....Ca
W
W
bean town ....Ca
7850 in the 1/8
Re: New video testing new converter [Re: WHITEDART] #2616565
02/03/19 07:26 PM
02/03/19 07:26 PM
bean town ....Ca
W
W
bean town ....Ca
There's the graph
Re: New video testing new converter [Re: WHITEDART] #2616683
02/04/19 01:20 AM
02/04/19 01:20 AM
N
n20mstr Offline
n20mstr  Offline
N
Why are these converters so loose at the stripe ? Does a small block require such a loose stator to get it going in the 60 , 330?
Re: New video testing new converter [Re: WHITEDART] #2616724
02/04/19 03:13 AM
02/04/19 03:13 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
The one I posted is an 1/8 mile pass, as are Shilohs. The Vette is set up to run 1/4 mile stuff. We were seeing 6-7% slip a the big end with the old set up. The new stuff is lockup stuff and be happy to report how it works once we get it all sorted out. It does allow us to run MORE gear in the rear too smile
Re: New video testing new converter [Re: dart games] #2616907
02/04/19 03:37 PM
02/04/19 03:37 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
offtopic
tsk shake_head
beer
Re: New video testing new converter [Re: dart games] #2616978
02/04/19 07:04 PM
02/04/19 07:04 PM
Cab_Burge Online work
Cab_Burge  Online Work
me thinks you need some teaching about BB Mopars compared to SB Mopars with the same rules devil whistling stirthepot
AKA, give credit where credit is due bow
I've made more HP per C.I. with a BB type Mopar motor N/A than I have with a SB or Hemi motor N/A realcrazy
Shilow motor is making a hoop of Power up bow
But we all need to keep in mind to run as fast or faster as the fastest guys out there in the same class your car needs to be perfect from the front bumper bolts to the rear bumper bolts and you have to have as good as or better parts than them and you need to be smarter and work harder than them also twocents work
I'm very lucky to have learned that lesson a long time ago helping other racers with more resources than me to set NHRA records and win NHRA world championships in Stock and SS boogie
Page 3 of 3 1 2 3
