Page 2 of 3 1 2 3
Re: Drag front shocks [Re: fowl play] #2616390
02/03/19 12:39 PM
02/03/19 12:39 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Originally Posted By fowl play
What front shocks are you running? A body small block 10.60 cars. Think my car could use some help. Reasonably priced if possible.
First, I think a couple of videos of the launch would help determine if there is a problem, or room for improvement, in the front suspension, rear suspension, weight transfer, hook. Almost anything in any car can be improved. Does it need it? Let's go to the instant replay first...
I see you're new to this site. Don't let all of the cross bickering get to you. You will find a thousand different ways to do things, depending on circumstances. Note all of the replies, group them together. determine which solutions might work best for you and why. There are thousands of years of experience on this site. Some very accurate, precise info. And some stuff from left field. Then there are some that just like to stir the pot. You will see a pattern on your own, soon enough. Welcome. Glad to have you on board. You will be going 10.0's soon enough with the help on this site.
Re: Drag front shocks [Re: sgcuda] #2616395
02/03/19 12:48 PM
02/03/19 12:48 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
. He has been a member since 2007 I'm just saying
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Drag front shocks [Re: fowl play] #2616465
02/03/19 03:44 PM
02/03/19 03:44 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Mid 10 sec. car has outgrown the 1960s technology 90/10 shock and would benefit from an upgrade I would think. You really only need or want the car to pitch rotate as much as it needs to help out the rear suspension. You're not making so much power that it doesn't need some help, unless it has big tires on it.
Re: Drag front shocks [Re: fowl play] #2616782
02/04/19 11:19 AM
02/04/19 11:19 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Buy a shock that allows you to grow in the future.
69 GTX 68 Road Runner
Re: Drag front shocks [Re: fowl play] #2616790
02/04/19 11:44 AM
02/04/19 11:44 AM
an8sec70cuda Offline
For the money, the Viking DA shocks are hard to beat. I'm very happy w/ the set on my cuda. Did some chassis tuning this weekend at the track and they responded VERY well.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Drag front shocks [Re: an8sec70cuda] #2616901
02/04/19 03:26 PM
02/04/19 03:26 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
The only reason why I'm OK w/ having S-A front dampers is because they're the QA-1 'R' series that have a very firm fixed compression circuit and a wide range of adjustment on the rebound (extension) circuit. For my nose-heavy junk, a stiff compression setting is kind of a given, so the primary changes of the front suspension are the ride height & available travel from the static ride height and the rate of extension off the line.
However, I'm still equipped with ancient 5-adjustment Rancho rear dampers. At some point I'm sure the car will benefit from D-A rear dampers, but I need to see how far I can take it using what's paid for already.
As someone else mentioned, I'm also used to having the wide range of suspension tuning adjustments with modern off-road motorcycles. Most Joe Average drag car components are comparatively stone-age.
Re: Drag front shocks [Re: fowl play] #2616905
02/04/19 03:34 PM
02/04/19 03:34 PM
MD
JACK1440 Offline
JACK1440  Offline
MD
I went to Vikings DA last year and have struggled to get them to work with the super stock springs. But... that's just my lack of testing. Gotta find that sweet spot
Re: Drag front shocks [Re: JACK1440] #2616919
02/04/19 03:58 PM
02/04/19 03:58 PM
Washington
madscientist Offline
Washington
There may not be a sweet spot with that spring and shock combo. Think about what you are doing with the spring and how the shock is not helping.
That spring is designed to arc and cause separation and smash the tire into the ground. For that to happen, the shock can have almost little to no rebound dampening. The shock you are using at its least amount of extension is too much dampening to allow the spring to work.
IMHO, you're better off going to a split mono spring and a set of Asassin bars. I like them better than the Calverts for the adjustability. I also prefer the slide-a-links better than Calverts for street/strip stuff.
With what you are doing, you are beating against the air. You want to make the shock control a spring that functions by not being controlled.
Just my thoughts on your situation.
Re: Drag front shocks [Re: fowl play] #2616924
02/04/19 04:10 PM
02/04/19 04:10 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
After smashing so many oil pans I went back to stock Monroe matics front shocks. $30. bucks each. Out of control wheelies with 90-10's was ridiculous . Now 10.30 at 130mph. is good enough with the wheels just up a little at launch. Could a multi adjustable be better? Not from my wallets view.
Re: Drag front shocks [Re: rowin4] #2616929
02/04/19 04:42 PM
02/04/19 04:42 PM
Washington
Washington
You need DA shocks way more than you think. A stick DEMANDS a good shock.
Re: Drag front shocks [Re: fowl play] #2616940
02/04/19 05:03 PM
02/04/19 05:03 PM
rowin4 Offline
rowin4  Offline
So what will the DA shock do , I have weight transfer , I don't want the wheels in the air to shift , been there done that transmission carnage. It caries the wheels out 40-50 feet now , down for the shift then back up again.
Re: Drag front shocks [Re: rowin4] #2616962
02/04/19 05:46 PM
02/04/19 05:46 PM
Washington
Washington
Nothing. Sounds like you have it tuned perfect.
Re: Drag front shocks [Re: BradH] #2617028
02/04/19 09:12 PM
02/04/19 09:12 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I ran these same shocks on my 64 Belvedere before swapping to double adjustable Afcos. Ran them 2 clicks from full stiff. They were actually pretty good. Got the car below 1.3 60ft with them.
Doug
Re: Drag front shocks [Re: dvw] #2617179
02/05/19 04:06 AM
02/05/19 04:06 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
Buy the best DA shock you can afford. Not everone wants to, or has the money for Santhuffs. Strange Eng, Viking or AFCO's are more wallet friendly, all can be rebuilt and re-valved down the track.
Alan Jones
Re: Drag front shocks [Re: LA360] #2617190
02/05/19 05:12 AM
02/05/19 05:12 AM
Cab_Burge Online work
Cab_Burge  Online Work
Its really to bad that Koni doesn't still sell the SPA speed sensing front shocks any more whiney
Re: Drag front shocks [Re: fowl play] #2617213
02/05/19 10:24 AM
02/05/19 10:24 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Currently swapping out my Strange single adj for some Afco doubles on the front. Car went into some crazy wheel stands at the New Years race. Hope to calm it down and retain the low 1.2ish 60 times I was getting, but also to catch the fall if I don’t. Luckily with my tube k set up my oil pan is wide, not deep or i would have really gotten a treat $$$.
Re: Drag front shocks [Re: J_BODY] #2617223
02/05/19 10:47 AM
02/05/19 10:47 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Jay, did you order the bounce control also?
Re: Drag front shocks [Re: Cab_Burge] #2617246
02/05/19 11:49 AM
02/05/19 11:49 AM
BradH Offline
BradH  Offline
No great loss: they aren't very good compared to what's available now since they had limited extension adjustment and no compression adjustment (and were extremely soft on compression, which is why they recommended not using them on big-block cars).
I had a set for B/E bodies where one stopped working. Koni said they could still rebuild them, but the cost was at least twice what I paid for the set originally. I got tired of them taking up shelf space about a year ago and sent 'em to the scrap heap.
BTW, any good hydraulic valving design is "speed sensitive". A progressive shim stack allows for light damping at slow shaft speeds and increased damping at faster speeds. This goes back to the fact that "traditional" car dampers are freakin' archaic compared to what any production motocrosser made in the last 30 years came with.
Re: Drag front shocks [Re: dvw] #2617248
02/05/19 11:54 AM
02/05/19 11:54 AM
BradH Offline
BradH  Offline
Doug
I'll need to tighten up mine a few clicks next time the car makes it to the track. IIRC, they were on the lightest extension setting and I could hear & feel the suspension bang up against the bumpers. If I can slow 'em down a tad w/o hurting the 60-ft, that'll be an improvement.
Re: Drag front shocks [Re: BradH] #2617264
02/05/19 12:30 PM
02/05/19 12:30 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Doug
This is where slow motion video, and a good person filming is valuable.
Page 2 of 3 1 2 3
