Re: Factory Showdown and SS/AH allowed in Comp [Re: theraif] #2615723
02/01/19 09:14 PM
02/01/19 09:14 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
It appears the current CIC doesn’t kick in at all until .610 under, in eliminations.
At .710 under, during eliminations, there’s a permanent index adjustment.
It certainly doesn’t look like a ss/ah car will be very competitive at the typical ET’s they run.
I wonder how many takers they’ll get.
As per nhra 2016:
“A new “Personal Index” is being added to the CIC system, to decrease the potential for class index adjustments when favorable conditions at an event may contribute to extraordinary performances that may not be the case in other parts of the country. The personal index will be applied when an individual records a .610 under or greater run during eliminations. The class index will only be adjusted when a run of .710 or greater is recorded during eliminations. Both will be adjusted on .01 increments with no plateaus up to a .10 maximum adjustment per event to a class index.”
What isn’t clear to me at the moment is whether this particular CIC rule only pertains to runs made during what are deemed “mineshaft” conditions, of if it’s just the way the CIC is now being done.
Re: Factory Showdown and SS/AH allowed in Comp [Re: CMcAllister] #2615873
02/02/19 04:58 AM
02/02/19 04:58 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Originally Posted By CMcAllister
If you run over .50 under in eliminations, you get hit with the amount that you went under for the rest of the event. Over .50 under that and you get hit again. It's not permanent until you go .60 under. They are always tinkering with the CIC, but I believe that's correct.
Qualifying doesn't count. At the last race in Pomona, 23 cars showed up, #1 qualifier went .72 under and the #21 guy was .488. So a Hemi car in AH/SM, the new class designation, going .35 under at 8.40, is going to need some help.
Yes this is correct.
NHRA isn't doing the AH cars any favors with this move.
Re: Factory Showdown and SS/AH allowed in Comp [Re: NANKET] #2615874
02/02/19 05:34 AM
02/02/19 05:34 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
And the manufacturers aren't looking to move any AH cars........coincidence ?
I'm not so sure.
Re: Factory Showdown and SS/AH allowed in Comp [Re: Dave Hall] #2615941
02/02/19 01:42 PM
02/02/19 01:42 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Originally Posted By Dave Hall
Comp is still a bracket race. Ask Dan Fletcher...
Well Mr. Fletcher has forgotten more about all of drag racing than I will ever know. However I don't see where anybody can say Comp is a bracket race.
1. You don't set your dial.
2. There are no breakouts.
Its handicap racing for sure, but not bracket racing.
Another observation is that I think this makes sense for the FS/XX cars as they only have eight races a year in FS/XX trim. However the SS/AH cars can run Super Stock at every national event. Between that and the tough index that does not make much sense to me but I might be missing something.
Re: Factory Showdown and SS/AH allowed in Comp [Re: theraif] #2615946
02/02/19 01:49 PM
02/02/19 01:49 PM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
After reading all these 100% legit comments and observations- NO WONDER- why COMP eliminator is dying !!
Hell ... it was on semi life support when I was a NHRA major sponsor!
Wally Parks would have a HEART ATTACK if he was still alive if he could see what the higher ups in the NHRA have done to that association
Re: Factory Showdown and SS/AH allowed in Comp [Re: theraif] #2616063
02/02/19 05:58 PM
02/02/19 05:58 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
It's a high dollar class for sure. It becomes like Pro Stock when they are trying to find any .01. Then somebody in Canada goes .800 under and it's back to the drawing board. The game is the same as a bracket race. Cut a light and take as little stripe as possible.
