Lower ball joints for 1969 Chrysler Newport #2609542
01/20/19 09:34 PM
01/20/19 09:34 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Where would be the best place to buy lower ball joints for a 69 Newport ?
This does NOT have screw in lower ball joints .
The only supplier I have found is Rareparts in California , can order through Jegs . Is there anyone else ?
TIA
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Lower ball joints for 1969 Chrysler Newport [Re: tex013] #2609587
01/20/19 10:25 PM
01/20/19 10:25 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
You asking for a Drum brake car, or a BUDD 4 piston caliper, disc brake car?
Big difference.
On a disc brake car, the ball joint is part of the steering knuckle, and big $$$$$$$ to pay, if one can be found.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Lower ball joints for 1969 Chrysler Newport [Re: tex013] #2609602
01/20/19 10:44 PM
01/20/19 10:44 PM
Andrewh Online content
Andrewh  Online Content
assuming drum.
PST was and appears to be the most reasonable.
https://p-s-t.com/i-23159115-original-performance-standard-front-end-kit.html#!year%3D1969%7C%7Cmake%3DCHRYSLER%7C%7Cmodel%3DNEWPORT
for the price of their kit, you get both ball joints vs the lowers alone from rareparts.
Re: Lower ball joints for 1969 Chrysler Newport [Re: tex013] #2609658
01/20/19 11:59 PM
01/20/19 11:59 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Hemi ,
car has drum front brakes , knuckle/joint combined
Andrewh ,
thanks for that will discuss with owner . looks like a way better buy . Though he has supplied new upper joints already
Tex
New best MPH 130.32
Re: Lower ball joints for 1969 Chrysler Newport [Re: tex013] #2611501
01/24/19 12:13 PM
01/24/19 12:13 PM
KY
65pacecar Offline
65pacecar  Offline
KY
Rare Parts has the C-Body suspension parts for a good price, similar to the old MOOG quality parts. I have had good luck with them.
Re: Lower ball joints for 1969 Chrysler Newport [Re: hemi71x] #2612388
01/26/19 01:20 AM
01/26/19 01:20 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Big difference.
On a C-body, 68 was the last year for Budd brakes.
65-73 C-bodies use the same lower ball joints for drum and single piston 69-73 disc brake spindles.
The steering arm is part of the ball joint on these too.
If you can source a set of 69-73, preferably 73 disc spindles, now would be a good time to upgrade to disc brakes.
Kevin
Re: Lower ball joints for 1969 Chrysler Newport [Re: Twostick] #2612390
01/26/19 01:32 AM
01/26/19 01:32 AM
hemi71x Offline
hemi71x  Offline
Big difference.
Kevin
Oops, your right about the disc brakes, year.
My bad.
I knew that, got the year wrong, and you refreshed the memory banks in the old cranium.
How about Rare Suspension Parts in Stockton, California?
Re: Lower ball joints for 1969 Chrysler Newport [Re: tex013] #2615327
01/31/19 10:56 PM
01/31/19 10:56 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
sorry for slow reply
customer ordered the PST kit . at least there will be some spare bushes , am I correct in thinking the upper ball joint is the same as a 68/69 b body ? the Newport upper takes the same ball joint tool .
Tex
New best MPH 130.32
Re: Lower ball joints for 1969 Chrysler Newport [Re: tex013] #2615339
01/31/19 11:25 PM
01/31/19 11:25 PM
no, it is different, but it is the same size tool.
tool works for later a, all b and c.
there is one size smaller for early a and one larger for trucks.
