Re: removing broken exhaust stud - having trouble welding
[Re: poorboy]
#2614238
01/29/19 08:11 PM
01/29/19 08:11 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
If the stud is 1/8" below the head surface, how are you not welding the nut to the first thread in the head?
For a broken 3/8 stud use a 5/16 nut. Aim the mig wire for the center of the stud (need to make sure you have adequate heat) then use a circular motion to finish the weld. Works well. The broken stud can be deeper than you think. One time in work I saved a bunch of money extracting a large broken bolt in a very large pump base. It was several inches in the hole. I took a new bolt and drilled the center out. A good welder used a stick machine to weld the new bolt to the broken one. Used bees wax once the welding was done and it came out like butter.
[Re: Exit1965]
#2614525
01/30/19 12:18 PM
01/30/19 12:18 PM
Posts: 8,889 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Stanton - I was going to get some of those today. How would you tackle it, start with a tiny one, drill all the way through, or just start chipping away with one close to stud size? I would drill a smaller pilot hole with a regular drill bit. Deep enough for the next size to follow. Then go at it with as large of a reverse bit as you feel safe with. It doesn't hurt to have soaked the stud with penetrating oil or such before hand to help it come out.
[Re: Exit1965]
#2614995
01/31/19 12:45 PM
01/31/19 12:45 PM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
All the advice from everyone is good except they seem to forget one thing.....Its a 1973 360. im not even gonna remind you of how old that is. your best bet is to drill out the hole and heli coil it to stock size. that is 5/16. If you cant drill it strait pay someone who can or pull the head and have an engine shop do it. Ive removed hundreds of broken ext. studs and bolts out of all kinds of heads and never had good luck doing That stud they are very difficult to say the least. metal stud iron head. you would think it would come right out but that is not the case with small block mopar outter ext studs. good luck
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
[Re: Exit1965]
#2615255
01/31/19 08:27 PM
01/31/19 08:27 PM
markz528
Morrow, OH
I had a recollection just now, about welding. I'm using thin .025" wire, and I think when I've tried to crank the amps up in the past, the thin wire just burns out without welding. I'm going to try a few attempts with .030" or .035" at higher amps and see if I can get those welds to stick to the stud.
Just in case I picked up left hand bits, transfer punches, a hinge-drilling kit (keeps drill centered in hole) in case welding with the heavier wire fails. I use 0.025" for this type of work. I also have a 0.035" larger welder but the smaller wire is the ticket. Practice first. Remember that you get more burn by adding wire speed not voltage. But both volts and feed have to be set correctly. You don't have to be scared of it being in the hole. The 1 size smaller nut and aiming for the center with a good burn and then circular motion works very well.
[Re: Exit1965]
#2616741
02/04/19 04:54 AM
02/04/19 04:54 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I have blown them out with a torch, chase the threads and install a new bolt/stud
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
