Page 5 of 5 1 2 3 4 5
Re: Inexpensive AN fittings [Re: mopar dave] #2615105
01/31/19 03:17 PM
01/31/19 03:17 PM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
I've had excellent luck with Earls UltraPro line. I think it's their top shelf stuff, also most expensive. PTFE lined.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: Inexpensive AN fittings [Re: mopar dave] #2615106
01/31/19 03:17 PM
01/31/19 03:17 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Fragola started as a private label maker and probably make stuff for Summit and others.
Re: Inexpensive AN fittings [Re: mopar dave] #2615316
01/31/19 10:46 PM
01/31/19 10:46 PM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
I use Earl's and Aeroquip and a Russel here and there if I cant find what I need in the other two.
I have quite a few old blue fittings from my swap to black on ebay....
eBay-cdwmotorsports
Re: Inexpensive AN fittings [Re: mopar dave] #2616735
02/04/19 04:02 AM
02/04/19 04:02 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I use Parker fittings for my braided teflon hoses, otherwise it is Aeroquip only. But I am using this on airplanes...
here is the best AN hardware book in the INDUSTRY..
https://www.askbob.aero/sites/default/files/Genuine_Aircraft_Hardware_Catalog.pdf
most people dont know that AN does not mean Air Force/Navy, it actually stood for Air Corps/Navy because the specs came out before there was an Air Force. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Inexpensive AN fittings [Re: RV2] #2616785
02/04/19 11:33 AM
02/04/19 11:33 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Originally Posted By RV2
For the past 4 years I have been buying all my hose and fittings from a place called "Getfast1"
Excellent pricing and no issues, the last batch of fitting were Fragola.
I bought 80% of my fitting for my Road Runner though them. It all looks nice... Haven't installed any yet.
69 GTX 68 Road Runner
Re: Inexpensive AN fittings [Re: astjp2] #2616871
02/04/19 02:23 PM
02/04/19 02:23 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Well thanks for that. I had one when I was in an aircraft facility and it got misplaced. Never remembered where it came from or how to get another. Just ordered a new one.
Re: Inexpensive AN fittings [Re: astjp2] #2616893
02/04/19 03:07 PM
02/04/19 03:07 PM
Does the FAA still require every part used on aircraft be certified with them?
