Re: IGN BOX
[Re: A/MP]
#2614240
01/29/19 08:18 PM
01/29/19 08:18 PM
Posts: 17,844 S.E. Michigan
ZIPPY
S.E. Michigan
Std motor products LX101 (NOT lx101T) is the only commercially/readily available halfway decent one I am aware of.
There are some fly by night ones out there sold by sensitive individuals. When you have a problem with their product, suddenly they ain't so sensitive anymore, though. They have their moparts fan base.
MP killed that whole product line, and...whatever...
Don't buy anyone's "house brand" painted orange.
This is one of the reasons I got away from them for basic street cars, and started going with HEI modules instead. TFI coil pairs up really nicely and gives a nice spark.
Rich H.
Esse Quam Videri
Re: IGN BOX
[Re: A/MP]
#2614273
01/29/19 09:34 PM
01/29/19 09:34 PM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I never really considered the gm hei route...... I had more of a “just put an msd in it” mind set.
But I can see the attraction to using a cheaper, readily available system like the hei conversion.
I’d def try it.
I like the idea of getting rid of the ballast resistor and running a modern style coil.
Re: IGN BOX
[Re: A/MP]
#2614649
01/30/19 05:18 PM
01/30/19 05:18 PM
fast68plymouth
So. Burlington, Vt.
Just google it...... there’s tons of info already out there.
Re: IGN BOX
[Re: hp340nos]
#2614682
01/30/19 06:23 PM
01/30/19 06:23 PM
ZIPPY
S.E. Michigan
to make a gm hei conversion what parts- hei modules are used and what type of coil to use with it?been following this post..thanks I went to a large E core coil, original application 1990 F150 with a 351. Cost about 9 bucks, and (per their charts) it is also compatible with both MSD6 and 7 series ignitions so it's pretty universal. For the module I looked up 1979 Corvette, but I think they are pretty much all the same. Makes a nice spark. Here is a thread I posted about it awhile back. https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2291558/1.htmlI've been thinking about making a batch of mopar-specific coil brackets for this setup but don't really know if they would sell. Seems most Mopar guys have not discovered the TFI coil yet.
Rich H.
Esse Quam Videri
Re: IGN BOX
[Re: boomerodell]
#2614973
01/31/19 11:58 AM
01/31/19 11:58 AM
Posts: 3,916 usa
lewtot184
usa
Hopefully the link works but this box is amazing. No ballast resistor and a rev limiter. Plus Don is a great guy to deal with! Give em a call and they will set you up. http://www.4secondsflat.com/Ignition.html I use one of those boxes on one of my cars with a modified 440 and like it. seems to be very reliable, but it's $200+. I use the LX101 on another car, basically stock 440, and it seems to be reliable (been in use several years) and it's around $40 thru rock auto. for me i'll never go back to any box that has to have all the stand offs at the coil.
Re: IGN BOX
[Re: Cab_Burge]
#2615244
01/31/19 07:52 PM
01/31/19 07:52 PM
RapidRobert
with the furd coil/HEI module/70's (non mallory) elecronic dist as I posted in the prior noted thread, I didn't have the truck long after I added it (got an offer that I couldn't refuse) but it did start a bit easier so I think it definitely did run/perform better but nothing earth shattering.
Re: IGN BOX
[Re: Cab_Burge]
#2615257
01/31/19 08:32 PM
01/31/19 08:32 PM
ZIPPY
S.E. Michigan
Just living dangerously I guess Did you know a can of carb cleaner can create some serious shock and awe? I can't say what happened, but...The day after, a neighbor asked where the explosion came from
Rich H.
Esse Quam Videri
