How to remove valve seats #2612062
01/25/19 02:30 PM
01/25/19 02:30 PM
Arkansas
Adrielp Offline OP
Adrielp  Offline OP
Arkansas
Any tips for removing valve seats out of 6.4l BGE heads at home?
Adriel Paradise
Substation Design Engineer III
Re: How to remove valve seats [Re: Adrielp] #2612492
01/26/19 11:56 AM
01/26/19 11:56 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
IIRC 200 degrees in an oven and they fall out.
Re: How to remove valve seats [Re: Adrielp] #2612702
01/26/19 06:36 PM
01/26/19 06:36 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
hopefully they don't fall out of the head simply heating it to 200 degrees since the engine temp is 205-210 and the ex valve seat is probably much higher than that running down the road under load.
Re: How to remove valve seats [Re: Adrielp] #2613897
01/29/19 08:11 AM
01/29/19 08:11 AM
Canada
Max Weg Offline
Max Weg  Offline
Canada
Just run a tig weld bead on the seat and it will shrink it. Sometimes I weld a piece of flat bar across to pry the seat out.
Max Weg
Re: How to remove valve seats [Re: HotRodDave] #2622610
02/17/19 05:39 PM
02/17/19 05:39 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Sorry Dave i meant 200 celcius.
Re: How to remove valve seats [Re: Max Weg] #2622699
02/17/19 09:39 PM
02/17/19 09:39 PM
SoCal
Brian Hafliger Offline
SoCal
Max Weg
Yep, mig or tig a bead around until it falls out.
Brian Hafliger
