Re: Finish line rules [Re: Cab_Burge] #2613348
01/28/19 02:21 AM
01/28/19 02:21 AM
my own world
theraif Offline
theraif  Offline
my own world
skip to 14:20 in this vid
Re: Finish line rules [Re: mills.mopar] #2613364
01/28/19 03:31 AM
01/28/19 03:31 AM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Every track that I have raced at for the past 40 yrs has the same view on excessive braking. One warning and then DQ. Excessive braking is hitting the brakes hard enough to smoke the tires. Nothing really vaugue about it.
Ok
Re: Finish line rules [Re: cudatom] #2613378
01/28/19 04:31 AM
01/28/19 04:31 AM
southeast ky
mills.mopar Offline OP
southeast ky
Specifically I'm asking about IHRA tracks. I should have stated that in the first post. I've never been able to find a specific rule on this, that's the whole reason for me asking the original question...
Jeff
If you love it lube it
68 dart
37 dodge coupe
71 challenger
Re: Finish line rules [Re: theraif] #2613388
01/28/19 06:13 AM
01/28/19 06:13 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
That was cool. Most race cars have the brake bias to the back and that car looked like a stock setup. I saw ZERO loss of control though. He got off the brake when the race was over.
Re: Finish line rules [Re: mills.mopar] #2613441
01/28/19 12:01 PM
01/28/19 12:01 PM
New York
polyspheric Offline
polyspheric  Offline
New York
A "rule for excessive braking"?
The rule is: someone important doesn't like it. That not a rule, that's an opinion.
The entire point of having rules is NOT to rely on someone's opinion.
Boffin Emeritus
Re: Finish line rules [Re: mills.mopar] #2613452
01/28/19 12:23 PM
01/28/19 12:23 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Its a safety issue - if you are smoking the tires with excessive braking then - quite frankly you need to leave before you hurt yourself or somebody else. It was happening at Norwalk in the slower brackets to the point guys were spinning out at top-end playing the stripe. Scrubbing a little speed off is one thing but locking up your front tires is just plain stupid!
Re: Finish line rules [Re: mills.mopar] #2613454
01/28/19 12:25 PM
01/28/19 12:25 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Excessive braking is a universal rule, I would doubt any track would say they allow it. Some tracks have their own set of rules, such as a visible tail light, courtesy staging, no beer in the pits, and the like. There are 4 IHRA tracks in KY, Beacon, I-64, London and Clay City. Go on their website or call them to see if they have any rules in particular. I tend to stay North of the Ohio river, as some of those tracks still have single Armco guardrails and the tech inspection consists of handing in your tech card to a teenage girl in the tower.
Re: Finish line rules [Re: cgall] #2613466
01/28/19 12:57 PM
01/28/19 12:57 PM
southeast ky
southeast ky
Cgall. I'll agree with you 100% on the tech inspection down here! I used to race at Byron and RT 66, it's a whole other world down here as far as tech inspection goes... I don't understand it.
Jeff
68 dart
37 dodge coupe
71 challenger
Re: Finish line rules [Re: mills.mopar] #2613469
01/28/19 01:02 PM
01/28/19 01:02 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Remind me not use use logic in these remarks, doesn't seem to have any effect.
Boffin Emeritus
Re: Finish line rules [Re: polyspheric] #2613474
01/28/19 01:15 PM
01/28/19 01:15 PM
A727Tflite Online content
A727Tflite  Online Content
What logic was used and what was ignored?
Re: Finish line rules [Re: A727Tflite] #2613524
01/28/19 02:52 PM
01/28/19 02:52 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
I get it. I've seen the "rule" enforced differently even at the national event level, depending on who the offender was.
Tire smoke or no tire smoke? Crossed up or not? Under control or not? It's a judgement call, probably depending on how long it's been since someone slid the tires and hit the wall.
Re: Finish line rules [Re: mills.mopar] #2613527
01/28/19 02:59 PM
01/28/19 02:59 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
It is curious just how important a rule becomes immediately after it was violated with extreme consequences.
We used to have a stretch of public road that was a week end drag strip......unofficially , of course.
And it was perfect..........about a mile long to a dead end , no cross streets and businesses on one side that were closed.
It was all good until someone wrecked and / or got hurt.
Then it was verboten...usually till the next spring or summer.
A couple years back they installed curbing that made it a series of S turns and only wide enough for a single if you wanted to go straight.
One more reason why they call them " The Good Old Days ".
Re: Finish line rules [Re: mills.mopar] #2613590
01/28/19 05:02 PM
01/28/19 05:02 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Jeff
That was both IHRA, NHRA and outlaw tracks.
Ok
Re: Finish line rules [Re: cudatom] #2613596
01/28/19 05:22 PM
01/28/19 05:22 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
The left overs of locking up the tires at the stripe
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Finish line rules [Re: bigdad] #2613603
01/28/19 05:46 PM
01/28/19 05:46 PM
South Bend
John Brown Online content
John Brown  Online Content
South Bend
I believe it was the 68 or 69 NHRA Nationals that Judy Lilly blew out both front tires because of locking up the brakes in the lights trying to keep from breaking out. Nothing new here.
Re: Finish line rules [Re: DoubleD] #2613621
01/28/19 06:39 PM
01/28/19 06:39 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I agree 100%.
Nothing wrong with scrubbing a bit but most of that can be done with your right foot.
Also ...if you have to hold a tenth to win a race I would suggest buying my car.....it runs the number.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Finish line rules [Re: mills.mopar] #2613625
01/28/19 06:55 PM
01/28/19 06:55 PM
my own world
theraif Offline
theraif  Offline
my own world
i remember one time some racing buds and i were talking if we could make a stand alone abs set up
Re: Finish line rules [Re: mills.mopar] #2613899
01/29/19 08:25 AM
01/29/19 08:25 AM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
Over on ANOTHER PLACE ... there’s a huge topic about some racer allegedly hitting a CONE up on the big end .. laugh2
Re: Finish line rules [Re: mills.mopar] #2614252
01/29/19 08:43 PM
01/29/19 08:43 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
If being able to scrub a little speed is so much more important than a couple MPH why not just run a little wider tire so you can brake without locking em up.
Re: Finish line rules [Re: mills.mopar] #2614393
01/30/19 01:02 AM
01/30/19 01:02 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
"If the brakes are locking up in front on a drag specific car it is not set up properly." Don't tell Tommy Philips! haha
