Finish line rules
#2613178
01/27/19 08:28 PM
01/27/19 08:28 PM
Posts: 252 southeast ky
mills.mopar
southeast ky
What are your local track rules on finish line racing? The rules as far as I can tell is kinda a grey area... Obviously if you cross the center line or hit the wall your disqualified. I've had pretty good success at times losing 10 mph or so on the Finnish line and have got some flack for some smoke off the front tires.. just wondering what is your opinion or your tracks opinion on the matter.
Thanks. Jeff
If you love it lube it
68 dart 37 dodge coupe 71 challenger
Re: Finish line rules
[Re: mills.mopar]
#2613186
01/27/19 08:38 PM
01/27/19 08:38 PM
Posts: 43,243 Bend,OR USA
Cab_Burge
NHRA will disqualify you for doing that unless your opponent does it worst Is your local track a NHRA affiliate and insured with the same company with the same set of rules BTW, when you race at any track you have to use and follow their rules and you should know all of them to avoid conflict
[Re: mills.mopar]
#2613193
01/27/19 08:57 PM
01/27/19 08:57 PM
Posts: 608 TN
1DGEMAN
TN
I have seen the aftermath of excessive braking a couple of times with destroyed cars. It is just plain stupid to hit your brakes hard on the top end. Dial it hard cut a light and race it. If I were a race official at the top end any tire smoke or wobble you are gone.
Real Men shift for themselves
[Re: mills.mopar]
#2613197
01/27/19 09:01 PM
01/27/19 09:01 PM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
Excessive braking (tire smoke) is most often is a first offence warning, second disqualification. If you need to break that hard to stay under a dial you probably should dial a little tighter There have been many examples of racers looping, sliding into the wall or opponents lane trying scrub off speed too aggressively hence the rule. other than that I can not think of any Finish line rules
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: mills.mopar]
#2613201
01/27/19 09:13 PM
01/27/19 09:13 PM
Posts: 11,632 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
NHRA has observers at the national events looking for all kinds of stuff. Excessive braking, pulling off safety equipment before you got off the track, funny blinking lights, etc. They're on a schedule and don't want to have to clean up a mess or have people get hurt. Local tracks and divisionals, luck of the draw. I've seen flat tires and wrecked cars from it. Kind of stupid, but people still do it. Guys like the 4 caliper rear brake kits for that so they don't slide the front tires.
[Re: CMcAllister]
#2613204
01/27/19 09:18 PM
01/27/19 09:18 PM
W.I.N. Racing
Byron, NY
NHRA has observers at the national events looking for all kinds of stuff. pulling off safety equipment before you got off the track, funny blinking lights, etc. Forgot about the safety equip stuff
[Re: tubtar]
#2613264
01/27/19 11:21 PM
01/27/19 11:21 PM
mills.mopar
southeast ky
The point of my post was not to start a poop show... I was just asking what your tracks rule was on the matter... Because the rules are very vague on the matter.
For those of you that say I'm stupid to "drive" the finish line, I would love to race you! You are the easy ones to load on the trailer....
Jeff.
[Re: mills.mopar]
#2613285
01/28/19 12:00 AM
01/28/19 12:00 AM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I don't know that my local track has a rule, and there's no one down there all day watching for it. Most local places are probably the same. I watch some of the high dollar stuff that's live stream and there's some aggressive finish line braking seen there on occasion. I guess it's part of the game. A lot of different finish line strategies in use.
[Re: mills.mopar]
#2613288
01/28/19 12:05 AM
01/28/19 12:05 AM
Posts: 22,696 Bitopia
jcc
Bitopia
Are cars required to have operational brake lights so whatever they are doing, its obvious to everybody?
[Re: jcc]
#2613297
01/28/19 12:18 AM
01/28/19 12:18 AM
mills.mopar
southeast ky
Are cars required to have operational brake lights so whatever they are doing, its obvious to everybody? As far as I know just one red "running" light. No functioning brake light.
[Re: mills.mopar]
#2613328
01/28/19 01:23 AM
01/28/19 01:23 AM
Posts: 7,495 Minnesota
Hemi_Joel
Minnesota
What is "tossed a salad"?
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: mills.mopar]
#2613331
01/28/19 01:36 AM
01/28/19 01:36 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
I read through the entire post......I missed anyone calling anyone stupid. I think the consensus is clear......if you smoke the fronts going through the lights , you are going to attract some official attention. And it seems like most feel it is justified. If you can " drive the finish line " and not smoke your front tires or veer into the wall , then you have done nothing wrong from my chair. Our approach has always been to run our race and let the chips fall where they may. Whoever is in the other lane is not all that important. Certainly not as important as they think.
[Re: mills.mopar]
#2613336
01/28/19 01:59 AM
01/28/19 01:59 AM
Cab_Burge
Jeff. Which rules are vague, your track rules or NHRA rules? As far as racing in brackets or handicap racing I'm your sugar daddy, when and where do we race I've been beat by .0004 (by John Calvert) and I've beat others by .0001 I have cut one perfect .400 light in super class racing also when division 7 race both S/P, Pro ET and both S/G and S/ST on a .400 pro tree That was long before anyone had come out with the delay boxes we have and use today
