Re: Cylinder scratches
[Re: Cab_Burge]
#2613674
01/28/19 08:35 PM
01/28/19 08:35 PM
69cornetr/t
69cornetr/t
This for everyone who wanted to know. Talked to my machinist, who's also a drag racer take a piston out look at it and ,"if it's not black death don't worry about it" which is the skirt gaulding the cylinder wall leaving black lines on the piston skirt.clean the cylinder wall with WD40 So I'm good to go.
[Re: ]
#2613698
01/28/19 09:22 PM
01/28/19 09:22 PM
Posts: 4,457 Washington
madscientist
Washington
This for everyone who wanted to know. Talked to my machinist, who's also a drag racer take a piston out look at it and ,"if it's not black death don't worry about it" which is the skirt gaulding the cylinder wall leaving black lines on the piston skirt.clean the cylinder wall with WD40 So I'm good to go. If they are only black on the back side i.e. the non thrust side that's from running a plug that's too hot. I've seen it many times. Back siding is usually the wrong plug.
[Re: ]
#2613708
01/28/19 09:53 PM
01/28/19 09:53 PM
69cornetr/t
69cornetr/t
Really? No black,but When you say back side do you mean toward the cam and why would a hot plug cause that? Running lean?
