heat shrink hose clamps?
#2611954
01/25/19 08:57 AM
01/25/19 08:57 AM
Posts: 294 indy
70moparmike
indy
were would you find heat shrink hose clamps? have seen them on a few cars and looks really clean instead of using hose clamps. thanks moparts
Re: heat shrink hose clamps?
[Re: 70moparmike]
#2612502
01/26/19 12:09 PM
01/26/19 12:09 PM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
they look great but are single use. get a bunch unless you plan on NEVER taking apart your car. One of the things I hate the most is a non serviceable part.
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
[Re: moparmarks]
#2612579
01/26/19 02:36 PM
01/26/19 02:36 PM
Posts: 4,684 Wichita
GY3
Wichita
I use them on my car and I absolutely love them!
[Re: TJP]
#2613249
01/27/19 10:50 PM
01/27/19 10:50 PM
Posts: 1,307 BC, Canada
Black_Bee
BC, Canada
I've run them on my '69 Bee for close to a decade now... not a drip. Its not a daily driver, but it sees enough use that any issues would have shown up. I was worried about the "single use" nature of the clamps too, but they sure clean up the look and I've actually not had a reason to take any of them off yet since they don't ever leak. One day I will need to remove them, and when I do, I will replace them with the same thing.
Paul '69 Super Bee 383 EFI Turbo
[Re: BDW]
#2613259
01/27/19 11:12 PM
01/27/19 11:12 PM
Posts: 140 Akron, ohio
76orangewagon
Akron, ohio
Can you take them off without destroying the hose? Or do you have to replace the whole deal. I use a soldering iron to cut through them and the hose is left untouched and reusable.
[Re: BDW]
#2613272
01/27/19 11:35 PM
01/27/19 11:35 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Can you take them off without destroying the hose? Or do you have to replace the whole deal. Soldering iron or they do have a really sweet tool that does only that, if you're the type that must have the right tool for everything https://youtu.be/4O91YqHbp8c?t=187
[Re: 70moparmike]
#2613384
01/28/19 05:38 AM
01/28/19 05:38 AM
Posts: 2,806 Northern NJ
StukaJU87
Northern NJ
This is the first I am seeing of these. They do give a clean look when installed.
Scott
1969 Super Bee, 383/4 speed
