Piston to valve clearence checking ?
#261283
03/21/09 10:54 PM
03/21/09 10:54 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
How much clearence should I have doing the 10* BTDC to 10* ATDC check? I have checked by using zero lash ( lash is .018") and then added .100" at the retainer and had no interference. Is this sufficient, or should I make additonal checks?
I also checked at max lift and I can push the rocker on further to bottom on the seal never hitting the piston.
Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Piston to valve clearence checking ?
[Re: Hemi Allstate]
#261284
03/21/09 10:58 PM
03/21/09 10:58 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I like to clay them also but the .100 is enough if you checked it every degree from about 15 before to 15 after just to make sure ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#261285
03/21/09 11:05 PM
03/21/09 11:05 PM
Hemi Allstate
Mt. Eden Ky.
I pre loaded the rocker .100" and rotated the crank. I never had inteference. Should I check BTDC & ATDC as well? I usually use clay too but I was trying to measure this one.
Thanks, Mark
[Re: Hemi Allstate]
#261286
03/21/09 11:14 PM
03/21/09 11:14 PM
MR_P_BODY
Well if you want to measure it, start at 15 before and press the valve down till it hits and take your reading(on your dial indicator) every degree to 15 after then you will know if you can move the degreed centerline for future reasons ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#261287
03/21/09 11:22 PM
03/21/09 11:22 PM
Hemi Allstate
Mt. Eden Ky.
What would be acceptable numbers in that range? Should I be able to read max lift or some thing less? Is this BTDC on compression stroke ? I appreciate your help.
Thanks, Mark
[Re: Hemi Allstate]
#261288
03/21/09 11:30 PM
03/21/09 11:30 PM
MR_P_BODY
Thanks, Mark
With 0 lash, start at 15 before, 0 the indicator then press the valve till it touches write down that number, continue doing it till 15 after... the same way, zeroing each time before you press it down, this will give you your max at each degree... in case you want to advance the cam in the future(or retard it) .100 is fine ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#261289
03/21/09 11:46 PM
03/21/09 11:46 PM
Hemi Allstate
Mt. Eden Ky.
Thanks, Mark
Sorry to ask so many questions, I just wanted to be clear on this. I made a few checks starting at 10* before and was getting .250" minimum, but wasn't sure if that was OK. I will recheck starting at 15 BTDC. Thank you again, ![](/ubbthreads/images/graemlins/thumbs.gif) Mark
[Re: Hemi Allstate]
#261290
03/22/09 12:00 AM
03/22/09 12:00 AM
MR_P_BODY
Sounds like you have a ton of room, I said 15 only because about 10 degrees is usually the close spot but not always. The reason I say to get a real number is you dont know what you have if you put a .100 spacer in it, thats one of the reasons I like to clay but also get a number at each degree for advance or retard purposes ![](/ubbthreads/images/graemlins/wave.gif)
[Re: dthemi]
#261292
03/22/09 12:08 AM
03/22/09 12:08 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Like P said 10 before will be closest on the ex and 10 after will be closest on the intake.
Nice looking mill too!
![](/ubbthreads/images/graemlins/iagree.gif)
[Re: Hemi Allstate]
#261296
03/22/09 12:41 AM
03/22/09 12:41 AM
MR_P_BODY
Thanks Mike! Moparts comes through again! ![](/ubbthreads/images/graemlins/thumbs.gif)
Mark
My pleasure.... good lookin engine ya got there ![](/ubbthreads/images/graemlins/thumbs.gif) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: 602heavy]
#261298
03/22/09 01:43 PM
03/22/09 01:43 PM
Hemi Allstate
Mt. Eden Ky.
Thanks to all for the help, and kind words. ![](/ubbthreads/images/graemlins/beer.gif) Mark
