Re: Dan Jesel designs his own 12,000 rpm pushrod engine.
[Re: Spaceman Spiff]
#2611336
01/24/19 12:12 AM
01/24/19 12:12 AM
Posts: 4,212 New York
polyspheric
New York
And the big secret is... (wait for it): Ta Da! Raised the cam into the valley. Just like Arias did 30 years ago.
Boffin Emeritus
#2611338
01/24/19 12:15 AM
01/24/19 12:15 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
And that's N/A,,,,,,,,,,,,,, ![eek eek](/ubbthreads/images/graemlins/custom/eek.gif)
#2611395
01/24/19 02:05 AM
01/24/19 02:05 AM
polyspheric
New York
By the way, for an idea of how "not new" the simple expedient of raising the cam to shorten the pushrods, Parilla made a 175cc "shoulder cam" using this principal in a production bike in 1952. Yes, it's just that simple.
Boffin Emeritus
#2611428
01/24/19 03:40 AM
01/24/19 03:40 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Interesting that he designed it for ball/cup pushrods instead of the popularity of ball/ball pushrods. I would think that with that much pressure and stress, rocker adjuster would have cup design. Im sure there is way more to it though.
[Re: Chargerfan68]
#2611450
01/24/19 06:51 AM
01/24/19 06:51 AM
Posts: 4,457 Washington
madscientist
Washington
Interesting that he designed it for ball/cup pushrods instead of the popularity of ball/ball pushrods. I would think that with that much pressure and stress, rocker adjuster would have cup design. Im sure there is way more to it though. It depends on how accurate the whole system is. There are advantages to the ball/cup system IF you have everything else where it should be, AND you know why you used a ball adjuster and why you set the ball where you did. If there is virtually no pushrod angularity the actual movement of the ball through the lift arc is pretty clean. It is interesting to say the least. Can wait to see it go across the dyno and then into the car.
