Dan Jesel designs his own 12,000 rpm pushrod engine. #2611231
01/23/19 08:43 PM
01/23/19 08:43 PM
jersey
Spaceman Spiff Offline OP
jersey
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Dan Jesel designs his own 12,000 rpm pushrod engine. [Re: Spaceman Spiff] #2611239
01/23/19 09:00 PM
01/23/19 09:00 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Pretty cool stuff! I'd like to hear it singing on the dyno or in an old modified production car.
Re: Dan Jesel designs his own 12,000 rpm pushrod engine. [Re: Spaceman Spiff] #2611289
01/23/19 10:56 PM
01/23/19 10:56 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Will it fit in an early A-Body?
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Re: Dan Jesel designs his own 12,000 rpm pushrod engine. [Re: Spaceman Spiff] #2611336
01/24/19 12:12 AM
01/24/19 12:12 AM
New York
polyspheric Offline
polyspheric  Offline
New York
And the big secret is... (wait for it):
Ta Da!
Raised the cam into the valley. Just like Arias did 30 years ago.
Boffin Emeritus
Re: Dan Jesel designs his own 12,000 rpm pushrod engine. [Re: Spaceman Spiff] #2611338
01/24/19 12:15 AM
01/24/19 12:15 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
And that's N/A,,,,,,,,,,,,,, eek
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Dan Jesel designs his own 12,000 rpm pushrod engine. [Re: Spaceman Spiff] #2611352
01/24/19 12:38 AM
01/24/19 12:38 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Clearly a RIP off of the small block mopar...only 4 head studs per cylinder. Lol
Re: Dan Jesel designs his own 12,000 rpm pushrod engine. [Re: Spaceman Spiff] #2611395
01/24/19 02:05 AM
01/24/19 02:05 AM
New York
polyspheric Offline
polyspheric  Offline
New York
By the way, for an idea of how "not new" the simple expedient of raising the cam to shorten the pushrods, Parilla made a 175cc "shoulder cam" using this principal in a production bike in 1952.
Yes, it's just that simple.
Boffin Emeritus
Re: Dan Jesel designs his own 12,000 rpm pushrod engine. [Re: Spaceman Spiff] #2611428
01/24/19 03:40 AM
01/24/19 03:40 AM
New York, USA
Chargerfan68 Offline
New York, USA
Interesting that he designed it for ball/cup pushrods instead of the popularity of ball/ball pushrods. I would think that with that much pressure and stress, rocker adjuster would have cup design. Im sure there is way more to it though.
Re: Dan Jesel designs his own 12,000 rpm pushrod engine. [Re: Chargerfan68] #2611450
01/24/19 06:51 AM
01/24/19 06:51 AM
Washington
madscientist Offline
Washington
It depends on how accurate the whole system is. There are advantages to the ball/cup system IF you have everything else where it should be, AND you know why you used a ball adjuster and why you set the ball where you did. If there is virtually no pushrod angularity the actual movement of the ball through the lift arc is pretty clean.
It is interesting to say the least. Can wait to see it go across the dyno and then into the car.
Re: Dan Jesel designs his own 12,000 rpm pushrod engine. [Re: Spaceman Spiff] #2611528
01/24/19 12:58 PM
01/24/19 12:58 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
These high end drag motors are starting to look like F1 engines! You have to admire the complexity and machine work on this - really shows the capability of the aftermarket industry.
Re: Dan Jesel designs his own 12,000 rpm pushrod engine. [Re: Spaceman Spiff] #2611529
01/24/19 12:58 PM
01/24/19 12:58 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I saw a video of the Jesel brothers being interviewed at SEMA about this engine.
It does have 5.00 bore centers which would make the engine illegal for many racing classes and series. They had to do this in order to get the cam bearings in the proper location for the straight pushrods.
As you can tell the heads are based on the P5 Mopar head.
If these engines are ever available to the public I can't feature how much they would cost. However if they just choose to make money on the manufacture and eat the development costs they might be an option for some.
However anyway I look at the the "Equal Eight" is one cool engine.
Re: Dan Jesel designs his own 12,000 rpm pushrod engine. [Re: Spaceman Spiff] #2611553
01/24/19 02:01 PM
01/24/19 02:01 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Pro-Mods are already up to a 5.30 bore spacing with some of those monster 900" nitrous engines - I am guessing this engine is going to be focused on some of the extreme outlaw classes
Re: Dan Jesel designs his own 12,000 rpm pushrod engine. [Re: Spaceman Spiff] #2611590
01/24/19 03:12 PM
01/24/19 03:12 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Bonneville. It's made for extra cooling to be able to run WFO for 5 miles.
