Headers 4 a 75 Cordoba 360 #2608335
01/17/19 11:53 PM
01/17/19 11:53 PM
Lost and Spaced
bboogieart Offline OP
Lost and Spaced
I have this Doba I would like to use for a daily driver this comming summer.
Looking at Accurate exhaust advertising here.
They have a complete system for duals at over $800oo.
They also say they are in limited supply.
I was wondering if there might be a header for this thing.
I can get the rest done at the local shop.
Don't wanna throw a grand at this thing for exhaust.
Thanx in advance folks.
I have mechanical Aptitude.
I can screw up anything.
Re: Headers 4 a 75 Cordoba 360 [Re: bboogieart] #2608348
01/18/19 12:13 AM
01/18/19 12:13 AM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
I looked on Summit's website and it looks like your header choice is very limited. Hooker 5115hkr is what fits. At $500 they are a little spendy in my book. Amazingly enough, if you had a big block, your header choice would be better.
Re: Headers 4 a 75 Cordoba 360 [Re: elmor353] #2608365
01/18/19 12:45 AM
01/18/19 12:45 AM
Lost and Spaced
Lost and Spaced
Thanks for the response.
That is a little spendy for this toy.
Re: Headers 4 a 75 Cordoba 360 [Re: bboogieart] #2608383
01/18/19 01:33 AM
01/18/19 01:33 AM
E
elmor353 Offline
elmor353  Offline
E
I just went to Jeg's website and had better luck. Looks like they have headers to fit your Cordoba starting at $250. In my way of thinking that's more like it.
Re: Headers 4 a 75 Cordoba 360 [Re: bboogieart] #2608423
01/18/19 02:59 AM
01/18/19 02:59 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
It's basically a B-body isn't it?
Kevin
Re: Headers 4 a 75 Cordoba 360 [Re: bboogieart] #2608494
01/18/19 10:56 AM
01/18/19 10:56 AM
scratchnfotraction Offline
I agree..250 range for a good set of hedmans or hooker for a little more maybe.
I had a 76 Daytona Charger SE 360 auto with a nice set of hookers.
first set of pipes were 2.5" straight pipe with 2 turbo muffs and 2' of tail pipe bent in a 90* dumping in front of the N50s.
one night about mid night at 110 mph a cat ran across the road, went under the front bumper and the CAT-muff-2' tail pipe all got sucked under the N50 at speed with a big bump & bang then 1 open header on the slow down. went back for my muff trash and it had cut the cat clean in two.
then with no cash outlay I had 2 thrush tin can mufflers welded to the bolt on collector and 2 small 45* x 8" long turn downs.
then it had the sound of power thrush tin cans were famous for.
IIRC trans R&R sucked with headers but well worth it.
Re: Headers 4 a 75 Cordoba 360 [Re: scratchnfotraction] #2608697
01/18/19 06:22 PM
01/18/19 06:22 PM
Lost and Spaced
Lost and Spaced
looked at JEGS, could find no such header.
Might you have a link?
Same at Summit.
Yes, a b-body, but unlike the older ones, due to front sub frame I would guess.
I was thinking of exiting in front of rear wheels.
Not looking to kill any kritters, but I appreciate the responses and the short story. I will have the pipes come out under the rear bumper.
Guess I'll see what Fran wants in town.
thing is I wasn't really looking for headers.
Couldn't find the head pipes anywhere.
Thanx guys.
Re: Headers 4 a 75 Cordoba 360 [Re: bboogieart] #2608791
01/18/19 10:36 PM
01/18/19 10:36 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Install a pair of exhaust manifolds from a mid-90's Ram or Dakota with a 318 or 360. They are a great design & should fit. I installed a pair of these on my 73 Charger 340 when I had it & they fit better than the original manifolds! Only thing I had to do was have a new trans dipstick assembly made as the RH side manifold interfered with the OE dipstick.
Re: Headers 4 a 75 Cordoba 360 [Re: bboogieart] #2608880
01/19/19 02:52 AM
01/19/19 02:52 AM
E
elmor353 Offline
elmor353  Offline
E
Patriot Exhaust H8206
Part Number: 737-H8206
Patriot Exhaust Dodge/Plymouth Specific Fit Headers All 1967-1982 A, B, E, & F Bodies
273-360 Small Block
1-5/8'' Primary Tubes
3'' Collectors
SAP Port Shape
Raw Finish
View Details
$249.93
I could not get the site link to load, but this is the info from Jeg's site. I just went on and entered the vehicle info and several sets of headers popped up.
Re: Headers 4 a 75 Cordoba 360 [Re: elmor353] #2608916
01/19/19 10:51 AM
01/19/19 10:51 AM
jersey
Spaceman Spiff Offline
jersey
$250 for a set of uncoated headers, that will be rusty in less than a year, doesn’t sound so good to me, especially if it’s a daily driver.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Headers 4 a 75 Cordoba 360 [Re: bboogieart] #2608932
01/19/19 11:57 AM
01/19/19 11:57 AM
RWG75
RWG75
The front sub frame change was 73. Most header application pages wont include 75/up because of emissions and generally omit Dobas because not considered a performance vehicle. Just about anything spec'd for small block B-body will fit. A couple tubes on drivers side go under the tie rod, passenger side is a bit snug, some install instructions say floor shift only but there's usually room to get around column shift.
If you're going headers only because you can't find an off the shelf head pipe, find a exhaust shop with skill. Custom bent duals from manifolds to bumper can be had for $500ish plus mufflers. Been a few years since I had any bent, your prices may be subject to inflation. I always supply my own mufflers to get what I want and skip the shop mark up. Getting past the gas tank on the drivers side is tight, but again an exhaust shop with skill can do it.
FWIW: best money to spend on waking up this pile of steel is swapping the rear gear. Probably 90% of them shipped with a 2.45 that will give long legs and decent mpg on the highway but won't get out of it's own way. Ya won't need more than a 3.21 to have a completely new car. Add a swap meet cast iron 340 intake, a TQ and maybe a purple shaft (if they still make them) and it's bucks down, fun up.
Re: Headers 4 a 75 Cordoba 360 [Re: Spaceman Spiff] #2609038
01/19/19 04:57 PM
01/19/19 04:57 PM
E
elmor353 Offline
elmor353  Offline
E
He asked about headers that fit. He didn't specify painted or coated. I don't see where you did any research to try and help the OP, just snide and negative remarks.
Re: Headers 4 a 75 Cordoba 360 [Re: elmor353] #2610623
01/22/19 08:00 PM
01/22/19 08:00 PM
Lost and Spaced
Lost and Spaced
Thanx elmor353 up
I also mentioned the local shop would be my next best option.
The car does Ok for get up and go, considering it's weight.
I have a 4 bbl and plan on an RV cam for some grunt.
Re: Headers 4 a 75 Cordoba 360 [Re: Spaceman Spiff] #2611120
01/23/19 04:22 PM
01/23/19 04:22 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I agree.
Also, headers are one of those things that you get what you pay for. I'd spend more now and avoid the headaches later. I get not wanting to dump a bunch of money into this car, but I LOVE YOUR DOBA! I think you should call TTI and see if they have something. I bet they do, and they'll seal up so nicely, and be trouble free for years and fit very well. twocents
Facts are stubborn things.
Re: Headers 4 a 75 Cordoba 360 [Re: bboogieart] #2611166
01/23/19 06:28 PM
01/23/19 06:28 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
find some that don't go under the steering arm. those are a pain. tti makes a set, yes they are expensive but you will crush the tube that goes under the arm, ask how I know. I think dougs also makes a set, check out ebay. search for headers that fit a 73+charger or road runner. same basic front suspension
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Headers 4 a 75 Cordoba 360 [Re: bboogieart] #2611180
01/23/19 07:18 PM
01/23/19 07:18 PM
P
Porter67 Offline
Porter67  Offline
P
$175 shipped
Ive bought a couple sets of these for beaters and they are actually nice for the cost.
China stainless. Headman knockoff
This part is compatible with 1 vehicle(s) matching 1975 Chrysler Cordoba Base Hardtop 2-Door 5.9L 360Cu. In. V8 GAS OHV Naturally Aspirated.
https://www.ebay.com/itm/Long-Tube-Exhau...0/333018998049?
Re: Headers 4 a 75 Cordoba 360 [Re: bboogieart] #2611207
01/23/19 08:18 PM
01/23/19 08:18 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
just found a summit brand that may go over the steering linkage, for $152
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: Headers 4 a 75 Cordoba 360 [Re: Jerry] #2611272
01/23/19 10:26 PM
01/23/19 10:26 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Could you share who makes them and a part number? I am interested in checking them out.
Re: Headers 4 a 75 Cordoba 360 [Re: bboogieart] #2611299
01/23/19 11:13 PM
01/23/19 11:13 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
Summit Racing Headers Full-Length Painted 1 5/8" Tubes G9040 Mopar 273-360 SB LA
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: Headers 4 a 75 Cordoba 360 [Re: Jerry] #2611316
01/23/19 11:35 PM
01/23/19 11:35 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Saw those. The Q&A under the listing on summitt says the steering link goes through the header pipes like most of the rest.I was hoping there was something new out there.
