Carb linkage ? #2610461
01/22/19 03:29 PM
01/22/19 03:29 PM
Western New York
sixpackbee Offline OP
Western New York
In uncharted waters again. Have a Hemi that is going to use an old Weiand TR. Sideways 4150's. What is a good throttle linkage kit to use. There are a few universal available. Just would like to be sure seeing they are good money for handful of parts. Thanks much.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: Carb linkage ? [Re: sixpackbee] #2610465
01/22/19 03:33 PM
01/22/19 03:33 PM
Washington
madscientist Offline
Washington
The Enderle is probably the easier and cheapest to use.
Re: Carb linkage ? [Re: sixpackbee] #2610466
01/22/19 03:33 PM
01/22/19 03:33 PM
Probably the Buchillion (SP?) cable kit would be your best choice scope
I've used the Lokar kit once and know of several others that had a hard time also getting it adjusted the way they wanted them to drive and kick down shruggy
IHThs
Re: Carb linkage ? [Re: sixpackbee] #2610469
01/22/19 03:38 PM
01/22/19 03:38 PM
Washington
Washington
Evidently I read the OP's post wrong. I thought he meant the linkage and not the throttle cable side of it. Sorry for the confusion.
Re: Carb linkage ? [Re: madscientist] #2610480
01/22/19 03:58 PM
01/22/19 03:58 PM
Oops, I misread it blush realcrazy That is what happens when I assume realcrazy
OP, the Enderle and several other ones not mentioned are excellent kits to use scope up
Summit list several good ones scope
Re: Carb linkage ? [Re: sixpackbee] #2610915
01/23/19 10:06 AM
01/23/19 10:06 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I had the Enderle kit on my sheet metal tunnel ram with 2 x 850's. I liked the kit. Easily adjusted. I had 1" spacers under my carbs so I bought a piece of aluminum hex stock, drilled and tapped it, for the rod from the intake bellcrank to the crossbar. I installed the crossbar mounts at the carb studs, but I've seen pics of them bolted to the top plate hardware.
Re: Carb linkage ? [Re: sgcuda] #2610931
01/23/19 11:16 AM
01/23/19 11:16 AM
Western New York
Western New York
Thanks guys. Ended up buying an Enderle. We'll see how it goes. Hopefully on the dyno in a few weeks.
1959 Bugeye Sprite
1971 MG Midget
Re: Carb linkage ? [Re: sixpackbee] #2611004
01/23/19 01:30 PM
01/23/19 01:30 PM
New York
polyspheric Offline
polyspheric  Offline
New York
If I had an odd application, I'd ask AndyF. If he doesn't make it, he's sure to have some ideas, and perhaps components?
Boffin Emeritus
Re: Carb linkage ? [Re: sgcuda] #2611153
01/23/19 06:07 PM
01/23/19 06:07 PM
Enderle stocks a bunch of different lengths rods with the ends on them for manifolds that are taller or shorter than their shelf kits fit, same thing on the carb. rods scope up
Re: Carb linkage ? [Re: sixpackbee] #2611173
01/23/19 06:52 PM
01/23/19 06:52 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Starting from this early, you have a chance to modify how "nervous" the throttle is between idle and tip in by changing the geometry.
Boffin Emeritus
Re: Carb linkage ? [Re: polyspheric] #2611355
01/24/19 12:55 AM
01/24/19 12:55 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
That's always just loads of fun,,,,,,,,,,,,NOT!!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
