1972 A Body/Demon Horns Prestolite or Spartan ?? #2610326
01/22/19 10:48 AM
01/22/19 10:48 AM
Land of 10,000 Lakes
44D6PAKCUDA Offline OP
Could someone post a picture of original 1972 A Body/Demon horns? Need to see if they were Prestolite or Spartan brand and if the brackets were bolted on or riveted on.Thanks for any help!!
Re: 1972 A Body/Demon Horns Prestolite or Spartan ?? [Re: 44D6PAKCUDA] #2610597
01/22/19 07:02 PM
01/22/19 07:02 PM
Bradford, Ontario
Barrelhouse Offline
Barrelhouse  Offline
Bradford, Ontario
Jim they are Sparton i have a mint set of hi and lo notes. Ed.
Re: 1972 A Body/Demon Horns Prestolite or Spartan ?? [Re: 44D6PAKCUDA] #2610704
01/22/19 09:49 PM
01/22/19 09:49 PM
SE PA
cudaize Offline
cudaize  Offline
SE PA
Jim,
Here is a picture of the horns on a 72 Dart I saved from an ebay auction that supposedly only had 28 miles. Also attached is the window sticker from the car so you can see SPD, plant, and other particulars to see how close to yours.
Mike Afflerbach
Re: 1972 A Body/Demon Horns Prestolite or Spartan ?? [Re: cudaize] #2610912
01/23/19 09:53 AM
01/23/19 09:53 AM
Thanks for the info Ed and Mike.Are the brackets on originals riveted on? I see some NOS ones were the brackets look like they either bolt on or are held on by a nut.It looks like in the one photo that they may be riveted on?
Re: 1972 A Body/Demon Horns Prestolite or Spartan ?? [Re: 44D6PAKCUDA] #2611040
01/23/19 02:27 PM
01/23/19 02:27 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Those look bolted, the slot at the end of the bracket is where a tab was bent to lock into the panel to keep it from twisting.
Joe
Re: 1972 A Body/Demon Horns Prestolite or Spartan ?? [Re: jlatessa] #2611060
01/23/19 02:53 PM
01/23/19 02:53 PM
Is the bracket where it attaches to the horn itself bolted on or riveted ?
