Re: Original or repro fendertag RM21V0A
[Re: gtx-guy]
#2609843
01/21/19 01:30 PM
01/21/19 01:30 PM
Posts: 673 Kennewick, Wa.
71vert340
Kennewick, Wa.
Which brings up the question: Why do some people block out part of the VIN when showing their tag(s)? I've had people take photos of my VIN tag and data plate at car shows, photos of copies of my broadcast sheets and original window sticker, etc. Is this some kind of protection? Terry
[Re: Little Detroit]
#2609904
01/21/19 03:26 PM
01/21/19 03:26 PM
Posts: 3,334 home of the Buckeyes
Butterscotch71
Lost Title
Lost Title
baloney!!!! education is the answer. you are not going to stop anything by with holding information. As I said before the best defence is a good offence. Its better to help someone "NOT LOSE THEIR SHIRT " than try prevent a suspected forger at getting better. If you truly believe that "fake tags " are that wide spread , and that this is your "true" calling then should you do everything in your power to educate everyone you can so they may determine for them selves if its real or fake. It seams as though some of you forgot that this a hobby/ business and you forgotten about the hobby side,"helping each other ". What good is it to have all the info and not share it with anyone. Others have helped you by volunteering their info (fender tags, broadcast sheets , and other info) for you to build your data base. Imagine if they were to take the same approach as you are, where would you be then? help the guy out he's obouvisly trying not to be swindled. If you spend enough time on this forum, you learn who the most informed are for spotting fake tags. They are very helpful in pointing out whether a tag is fake or not. That information alone is helpful enough for the OP. That doesn't mean they have to explain exactly what is wrong, and YES make it easier for the dishonest people to make more convincing tags. I side with Barry on this.
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
[Re: 71redcuda]
#2609908
01/21/19 03:33 PM
01/21/19 03:33 PM
Posts: 3,392 cheshire, ct
davesmopars
cheshire, ct
If you know just say fake or real. You do not have to say whats wrong with it. Barry what about the BO29 tag you never said anything about that one.
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
[Re: cbusters]
#2609999
01/21/19 06:43 PM
01/21/19 06:43 PM
Posts: 21,501 N.E. OHIO, USA
A12
N.E. OHIO, USA
Isn't the fender tag lifted (bent) up in one corner to facilitate painting underneath and then folded down? One screw painted body color and one a bare plated screw? Don't see any bend marks. "Usually" the other plants except or "usually" Lynch Road Assembly bent the fender tag right to left with the left screw in place. The Lynch Road fender tags were hanging (supposedly by a paperclip) somewhere inside the passenger's compartment maybe by the sun visor, mirror mount or steering column. So NO crease or fold mark on LR tags. EDIT, EDIT
[Re: A12]
#2610006
01/21/19 07:00 PM
01/21/19 07:00 PM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
"ALL" & "NEVER" usually don't belong in any Mopar discussions IMO the tag is "NOT AUTHENTIC". nothing I see specifically on the tag "rats" it out - is there any other documentation for the car?
#2610007
01/21/19 07:01 PM
01/21/19 07:01 PM
Posts: 29,650 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
I'll split this up some, just to cover a few points mentioned from my perspective. =Little Detroit] Its better to help someone "NOT LOSE THEIR SHIRT " than try prevent a suspected forger at getting better. I answer people emails asking if fender tags are fake or real all the time - for free. I have three websites with my contact information available, so I am not hard to find. It seams as though some of you forgot that this a hobby/ business and you forgotten about the hobby side,"helping each other ". It is a hobby for some & a business for some. A few different places make fake tags, why provide information to help them help their clients with better fakes? What good is it to have all the info and not share it with anyone. Others have helped you by volunteering their info (fender tags, broadcast sheets , and other info) for you to build your data base. Thousands of people have trusted me with their car data over the years. I use it to do good. If I started using what I have learned over the last 30 plus years to 'help' the dishonest people make fakes, I would lose the trust of thousands. help the guy out he's obouvisly trying not to be swindled. The OP asked about a Lynch Road tag, they are outside my area of study. I do have a lot of 1970 Lynch Road information filed though. But the photo the OP posted has part of the VIN blocked. So is it worth taking any time to try to look up? I file everything by VIN, so why try to look anything up based on a hidden VIN?
[Re: davesmopars]
#2610009
01/21/19 07:04 PM
01/21/19 07:04 PM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Barry what about the BO29 tag you never said anything about that one. 1968 Hamtramck? Again outside my area of study. I study 1970 LA & Hamtramck coding.
[Re: Alaskan_TA]
#2610021
01/21/19 07:29 PM
01/21/19 07:29 PM
davesmopars
cheshire, ct
Barry what about the BO29 tag you never said anything about that one. 1968 Hamtramck? Again outside my area of study. I study 1970 LA & Hamtramck coding. If you would like to know pm me and I will tell you so you have that info also.
[Re: A12]
#2610046
01/21/19 08:37 PM
01/21/19 08:37 PM
Posts: 5,123 Warrenton, VA
RoadRunnerJD
Warrenton, VA
Paint is a little thick but looking at it from the back, fonts, spacing and line spacing all seem to be the same as the originals pictured above? There is also some sign of pitting or aging on the back. Is anyone on here really expert enough to declare it a reproduction?
[Re: RoadRunnerJD]
#2610109
01/21/19 10:20 PM
01/21/19 10:20 PM
A12
N.E. OHIO, USA
Paint is a little thick but looking at it from the back, fonts, spacing and line spacing all seem to be the same as the originals pictured above? There is also some sign of pitting or aging on the back. Is anyone on here really expert enough to declare it a reproduction? OPINION JD just an opinion. So on the flip side "Is anyone on here really expert enough to declare it an original"....no but we're allowed to state an OPINION I think from now on I'm not going to state an opinion on any fender tags. Mike
[Re: 71redcuda]
#2610119
01/21/19 10:29 PM
01/21/19 10:29 PM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
Remade.
One should never guess.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: A12]
#2610126
01/21/19 10:45 PM
01/21/19 10:45 PM
RoadRunnerJD
Warrenton, VA
Paint is a little thick but looking at it from the back, fonts, spacing and line spacing all seem to be the same as the originals pictured above? There is also some sign of pitting or aging on the back. Is anyone on here really expert enough to declare it a reproduction? OPINION JD just an opinion. So on the flip side "Is anyone on here really expert enough to declare it an original"....no but we're allowed to state an OPINION I think from now on I'm not going to state an opinion on any fender tags. Mike Me neither!
[Re: A12]
#2610252
01/22/19 02:16 AM
01/22/19 02:16 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Paint is a little thick but looking at it from the back, fonts, spacing and line spacing all seem to be the same as the originals pictured above? There is also some sign of pitting or aging on the back. Is anyone on here really expert enough to declare it a reproduction? OPINION JD just an opinion. So on the flip side "Is anyone on here really expert enough to declare it an original"....no but we're allowed to state an OPINION I think from now on I'm not going to state an opinion on any fender tags. Mike Mike,maybe like this below,maybe yes,maybe no,may never know !! Major HEMI car stach found in Conn!!!!!!!! ( 1 2 3 ...17 18 19 ) by hemi-itis
[Re: davesmopars]
#2610260
01/22/19 02:38 AM
01/22/19 02:38 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Barry what about the BO29 tag you never said anything about that one. 1968 Hamtramck? Again outside my area of study. I study 1970 LA & Hamtramck coding. If you would like to know pm me and I will tell you so you have that info also. Barry doesn't use the PM system. You need to either email or snail mail him.
[Re: 71redcuda]
#2610272
01/22/19 03:14 AM
01/22/19 03:14 AM
Posts: 1,551 Sweden
71redcuda
Sweden
Thanks for all input. I will hopefully inspect the tag "live"soon when my friend send it over..
I dont want to show the full VIN when its not my car.
