Page 2 of 3 1 2 3
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: Lifsgrt] #2608798
01/18/19 10:51 PM
01/18/19 10:51 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
At only 7,200 rpm. you really aren't getting into where a finely tuned header will make that much difference. I would build a nice set of 2-1/4 to 2-1/2 step. You could even do like funny car double wall to keep the heat out of the car. You can make 240mph with a 2.95 rear ratio, (tranny 1.00 I presume) 33" tire, according to Wallace. Doesn't the car weigh more than 4,000 lbs.? At your level of play, drag coefficient is really where it's at. More hp on the salt will create more tire spin if it's fighting a brick wall.
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: Lifsgrt] #2608825
01/19/19 12:07 AM
01/19/19 12:07 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Ran your numbers again with(394 flow)= 111.24 VE and 8000rpm.
1071hp/765tq calling for a 2.182-2.307" tube 25.9-28.9 long.
HP/CI=2.51
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: mopar dave] #2608943
01/19/19 12:44 PM
01/19/19 12:44 PM
near St Petersburg, FL
Lifsgrt Offline OP
Lifsgrt  Offline OP
Hey Dave, does the program show the same numbers if you change the rpm to 8000 or 8500? Might need to turn the pump faster to make hp. Thanks
B3 1969 Charger R/T SE, 440/727 with 3:91s running 11.07@120
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: Lifsgrt] #2609232
01/20/19 05:28 AM
01/20/19 05:28 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Hey guys,thanks for all the feedback, I really appreciate it. I've decided to go with a two-step 2 1/4" to 2 3/8" with a 4" collector. The AlterKtion (to get rid of torsion bars and free space for the dry sump pump) should arrive next week, so I can get going on the headers. I hope to get the headers and dry sump together and stop by Best Machine on the way home to hear this beast sing! Then we'll know what it makes! Today is day 17 of the build, I've replaced inner and outer rockers, trans crossmember, and all four frame rails so far. Floor is obviously still out, and I got one wheelhouse out today with fresh one mocked in place. Finally getting something done on it! Thanks again!
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: Lifsgrt] #2609233
01/20/19 05:31 AM
01/20/19 05:31 AM
Cab_Burge Online work
Cab_Burge  Online Work
What car year and body style are you going to run on the salt flats?
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: Lifsgrt] #2609464
01/20/19 07:11 PM
01/20/19 07:11 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
OK, using 8500rpm target with same 111.24 VE/394 flow gets you 2.236-2.361 tube size 25.2-28.2 length. Collector length 13.8 or 6.9. Collector Dia 4.204-4.704 AVG HP 1156/769 TQ, HP/CI 2.321
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: Lifsgrt] #2609575
01/20/19 10:12 PM
01/20/19 10:12 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I'm going to guess 1080-1100HP@8200RPM.
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: Lifsgrt] #2609710
01/21/19 01:58 AM
01/21/19 01:58 AM
poughquag, NY
440GTX Offline
440GTX  Offline
poughquag, NY
I run 2 1/4 to 2 3/8s with a 4 inch merge collector on my 632 600-13 xxx headed motor
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: Cab_Burge] #2609748
01/21/19 04:55 AM
01/21/19 04:55 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Hey Cab, I'm planning to make Speed Week in August, touch base with me before to confirm. Definitely something a car guy should do before he pops the 'chute!
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: camastomcat] #2609749
01/21/19 04:57 AM
01/21/19 04:57 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
I'd certainly be happy with that Tom!
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: mopar dave] #2609750
01/21/19 04:59 AM
01/21/19 04:59 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Hey Dave, can you hang that 8500rpm data or send it to me? I would like to se ethe rest of the numbers. It looked like you were describing a two step header, thanks.
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: 440GTX] #2609751
01/21/19 05:00 AM
01/21/19 05:00 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
440GTX, what power and torque is that monster making?
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: Lifsgrt] #2609829
01/21/19 12:56 PM
01/21/19 12:56 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
here ya go
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: Lifsgrt] #2609868
01/21/19 02:15 PM
01/21/19 02:15 PM
poughquag, NY
440GTX Offline
440GTX  Offline
poughquag, NY
1240 hp and 920 ft pounds of torque
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: 440GTX] #2609935
01/21/19 04:20 PM
01/21/19 04:20 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
SHOW OFF!!
I was going to respond to this, but im not LOL
....BAD A$$ STREET CAR.....
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: Cab_Burge] #2610177
01/21/19 11:55 PM
01/21/19 11:55 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Hey Cab, building a 1969 Daytona clone for the task. I'm in Buckley, WA, come on up and have a look!
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: 440GTX] #2610180
01/21/19 11:57 PM
01/21/19 11:57 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
That's certainly stout 440GTX, thanks. How did you determine what type merge collector to go with, or did you just pick what you wanted? Do you have comparison with non-merge collectors by chance?
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: Lifsgrt] #2610202
01/22/19 12:32 AM
01/22/19 12:32 AM
poughquag, NY
440GTX Offline
440GTX  Offline
poughquag, NY
I always run a merge chuck from best machine helped me with the tubing size and talked to couple of other guy pretty much came up with the same thing
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: mopar dave] #2610288
01/22/19 05:05 AM
01/22/19 05:05 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Thanks again Dave!
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: Lifsgrt] #2610333
01/22/19 11:18 AM
01/22/19 11:18 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
thumbs
Page 2 of 3 1 2 3
