Page 2 of 4 1 2 3 4
Re: BB bellt drive, who makes them besides Jesel? [Re: Cab_Burge] #2609893
01/21/19 02:11 PM
01/21/19 02:11 PM
Las Vegas
Al_Alguire Offline
Happy Birthday Al_Alguire  Offline
Las Vegas
The Aussie Belt drives ALL have idlers. Jesel is just the raised cam stuff
Re: BB bellt drive, who makes them besides Jesel? [Re: Al_Alguire] #2610003
01/21/19 05:48 PM
01/21/19 05:48 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Originally Posted By Al_Alguire
I ran an old Australian Muscle Parts belt drive. I felt like I was the R&D guy for him. I finally quit emailing and just made it work. Would like to see his come back just for some competition. As for the idler it is on ALL the raised cam BB Mopar Jesel. If you are patient they can be located from time to time, I will warn you if you buy a used one and it needs a belt or seals may as well buy new. They are quite proud of their stuff
I have one on my small block........I bought it used , then started buying parts.
Yeah......if I do another motor with one , it will be new in box , from the manufacturer or distributor.
The set up I bought had the plate for a low deck small block , so I bought the backing plate too.
I didn't save a more than maybe 150.00 , but I got a solid understanding of how they want to go together and work. LOL
Re: BB bellt drive, who makes them besides Jesel?Update [Re: Cab_Burge] #2610893
01/23/19 04:27 AM
01/23/19 04:27 AM
Cab_Burge Offline OP
I decided to buy a new Mildon gear drive for this motor, it should be here by Friday, I hope luck
I've installed and race them as well as KB and Donovan gear drives, this current motor will have a little over 850 Lbs. over the nose and around 300 Lbs. seat pressure wrench
Thanks to all of you for your help up
Re: BB bellt drive, who makes them besides Jesel?Update [Re: Cab_Burge] #2610900
01/23/19 06:02 AM
01/23/19 06:02 AM
Washington
madscientist Offline
Washington
Not a single thing wrong with that gear drive.
Re: BB bellt drive, who makes them besides Jesel?Update [Re: Cab_Burge] #2611026
01/23/19 12:56 PM
01/23/19 12:56 PM
Las Vegas
Al_Alguire Offline
Las Vegas
I have used them twice. They work ok a tad fiddly on install IMO but work fine. 850 on the nose is not a big deal. Try 1300+ smile
Re: BB bellt drive, who makes them besides Jesel?Update [Re: Al_Alguire] #2611152
01/23/19 05:03 PM
01/23/19 05:03 PM
Try 1300+ smile
Not this week, maybe next week haha grin
My new Intercomp valve spring tester does go up to 1400 Lbs. work
Re: BB bellt drive, who makes them besides Jesel?Update [Re: Cab_Burge] #2622824
02/18/19 03:45 AM
02/18/19 03:45 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
was talking to Mike from 'Strayln Muscle parts today, said he is almost ready to release the new version of his belt driove for BBM's. we had a good talk & the new unit is going to have big improvements over the original. He's hoping the production will start in the next few months & hopefully priced better than the Jesel. He tells me Todd will probably be one of his dealers. watch this space
Re: BB bellt drive, who makes them besides Jesel?Update [Re: rebel] #2622953
02/18/19 03:05 PM
02/18/19 03:05 PM
Thanks for the heads up thumbs
Re: BB bellt drive, who makes them besides Jesel?Update [Re: Cab_Burge] #2623042
02/18/19 07:09 PM
02/18/19 07:09 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
He send me a pic of his new Ford unit, said his new Mopar one will look similar.
Re: BB bellt drive, who makes them besides Jesel?Update [Re: rebel] #2623110
02/18/19 10:17 PM
02/18/19 10:17 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Have never ran a belt drive but will be on my next engine. With that said is there a benefit with the idler. I know many of you have lots of experience with this stuff so I figured I will get the straight scoop.
Ok
Re: BB bellt drive, who makes them besides Jesel?Update [Re: Cab_Burge] #2623141
02/18/19 11:14 PM
02/18/19 11:14 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Looks great overall. Do you know if it will it accept a cover for some street use?
Re: BB bellt drive, who makes them besides Jesel?Update [Re: cudatom] #2623319
02/19/19 01:37 PM
02/19/19 01:37 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
The only reason to run the Idler from those pics is because there is not a belt that is an exact fit, the pulley takes up the slack. This single idler method also can change timing, that is why the cam pulley is adjustable, it compensates for any tightening or loosening of the belt. Its not a bad design, it has been proven on tens of thousands of accurate 3 axis milling machines to drive the spindle. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: BB bellt drive, who makes them besides Jesel?Update [Re: astjp2] #2623444
02/19/19 07:47 PM
02/19/19 07:47 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Thanks for the answer
Ok
Re: BB bellt drive, who makes them besides Jesel?Update [Re: Cab_Burge] #2623580
02/20/19 01:43 AM
02/20/19 01:43 AM
Midland,Tx
wyldebill Offline
wyldebill  Offline
Midland,Tx
Going to be completely honest, what are the advantages of the belt drive? Will you really see the horsepower per dollar?
Re: BB bellt drive, who makes them besides Jesel?Update [Re: wyldebill] #2623597
02/20/19 03:34 AM
02/20/19 03:34 AM
AndyF Offline
AndyF  Offline
There are a lot of advantages for a serious race engine. Not so sure that power is one of them.
Re: BB bellt drive, who makes them besides Jesel?Update [Re: Cab_Burge] #2623696
02/20/19 01:20 PM
02/20/19 01:20 PM
Midland,Tx
wyldebill Offline
wyldebill  Offline
Midland,Tx
I building a rather serious street car engine. I've looked at them, just hard to justify the expense. Especially since no one can give me any proven reasons.
Re: BB bellt drive, who makes them besides Jesel?Update [Re: wyldebill] #2623702
02/20/19 01:30 PM
02/20/19 01:30 PM
AndyF Offline
AndyF  Offline
Jesel belt drives, just like Jesel rocker arms are used on serious race engines. You can put them on a street car just for show, but they are designed for hardcore applications. Anytime I build an engine that is going to get beat on hard I use a belt drive. It is a good way to solve a bunch of issues at the front of the engine.
Re: BB bellt drive, who makes them besides Jesel?Update [Re: AndyF] #2623706
02/20/19 01:37 PM
02/20/19 01:37 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
100’s if not 1000’s of 8 second passes with my Mopar big blocks running roller timing chains with zero issues. Some get caught up in tricks, some don’t. Spend YOUR money wisely.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.38@138.67
Re: BB bellt drive, who makes them besides Jesel?Update [Re: wyldebill] #2623709
02/20/19 01:41 PM
02/20/19 01:41 PM
I've used a Jesel belt drive on one motor so far, I wasn't really impressed with it hence the choice on the gear drive for this current street motor.
To bad Cloyes has now goofed up all the better BB Mopar timing sets runaway whiney
Setting up a single idler gear drive can be a pain but it way better than breaking a timing chain in two or three years of street use or a belt up work
Re: BB bellt drive, who makes them besides Jesel?Update [Re: Cab_Burge] #2623871
02/20/19 06:15 PM
02/20/19 06:15 PM
Midland,Tx
wyldebill Offline
wyldebill  Offline
Midland,Tx
This engine will produce 950 to 1000 hp. Its pump gas brother made 864 with a bad carb and undersized headers. So were arent talking mild bracket car. I just cant see the justification of the dollars.
Page 2 of 4 1 2 3 4
