440 Motorhome head swap #2608496
01/18/19 11:00 AM
01/18/19 11:00 AM
Southern Oregon
toyotajeep Offline OP
Southern Oregon
I have regular 76 440 out of a truck I believe. No extra cooling holes on the block deck. For my purposes, I would like to run some motorhome(whatever you want to call them) 452 heads. The heads have the extra cooling holes near the spark plugs. Has anyone ran these heads on a non-drilled block 440? I am intending to use steel shim gaskets etc.
I'd really rather not drill the block as I am eventually going to do something a little more normal once the car is done.
Thoughts? I don't want things running hot. I personally think it will be fine, but I am just asking before I invest in the heads.
1989 Dodge Cummins & 1989 Dodge W-250
Re: 440 Motorhome head swap [Re: toyotajeep] #2608509
01/18/19 11:57 AM
01/18/19 11:57 AM
Abilene, Texas
fastmark Online content
fastmark  Online Content
Abilene, Texas
I’ve used the MH block with 906 heads and that ran hot on two different engines. Never gone the other way. I would think it should work ok. The 452MH heads are the same casting just machined a little different
Re: 440 Motorhome head swap [Re: toyotajeep] #2608512
01/18/19 12:01 PM
01/18/19 12:01 PM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
In my own limited experience: I ran a '73 Motorhome 440 with steam holes in the deck & heads, however, my Fel-Pro head gaskets blocked off the holes. I had no noticeable problems with cooling.
My particular motorhome heads took a different style of spark plug compared to a "car" head. Tapered seat with no gasket as opposed to a flat seat with a crush washer. Not sure if its a similar situation with your later 452's but thought I'd mention it anyway.
Re: 440 Motorhome head swap [Re: toyotajeep] #2608515
01/18/19 12:08 PM
01/18/19 12:08 PM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
If you have plans to deck the head surface at all and you are concerned about the holes, it would be easy to tap them for a pipe thread and run crack-repair pins into the holes, then cut off the excess and deck it flat. I've also seen small set screws used to plug steam holes.
Re: 440 Motorhome head swap [Re: toyotajeep] #2608523
01/18/19 12:16 PM
01/18/19 12:16 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
RV also have a different water pump housing to plumb to the heads....
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: 440 Motorhome head swap [Re: 68Cbarge] #2608542
01/18/19 12:57 PM
01/18/19 12:57 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
You’ve seen that pump housing on a 440? I’ve only seen it on a 413 and supposedly on a 361 industrial motor
Re: 440 Motorhome head swap [Re: dOoC] #2608547
01/18/19 01:09 PM
01/18/19 01:09 PM
Southern Oregon
Southern Oregon
Ok. I think the engine that has the "special" heads is likely motorhome, but not industrial. Other than the heads and the corresponding deck holes, it is largely identical to the other engine. It has a cast crank, but a windage tray and roller chain etc. I am saving it for the next build after this one. It has zero ridge etc. so it will be a good builder for later.
452 casting number, but I think there was an additional symbol on them or something. I will look later this weekend.
I have seen the "industrial" 440 engine, which I suspect came out of a really large motorhome. It was somewhat challenging to even identify as a Mopar with the external differences. Water pump, it seems like distributor, etc. Looked strange and it was partially hidden.
And you are correct on the plugs etc. they are different.
I am using these "holey" heads on the first build with the car. Going to do some bowl work etc. as they are pretty tight and use them while I gather parts for the next round next winter etc.
Re: 440 Motorhome head swap [Re: toyotajeep] #2608558
01/18/19 01:33 PM
01/18/19 01:33 PM
Abilene, Texas
Abilene, Texas
The usage on both of my MH blocks that ran hot were in Texas. That might have something to do with it. Never had any trouble with excess heat except for those two blocks.
Re: 440 Motorhome head swap [Re: fastmark] #2608605
01/18/19 03:00 PM
01/18/19 03:00 PM
On a side note for this app (heads/decks not milled flat) I would consider a composition gasket (or at least copper koat on the steel shims).
Re: 440 Motorhome head swap [Re: RapidRobert] #2608614
01/18/19 03:13 PM
01/18/19 03:13 PM
Southern Oregon
Southern Oregon
Definitely the copper coat for sure. The thing has such low-compression that I don't want to lose any.
I bought the shim gaskets in addition to the regular Fel-Pro ones so I can run either if need to.
Don't want leaks but I do want compression.
Re: 440 Motorhome head swap [Re: toyotajeep] #2608623
01/18/19 03:20 PM
01/18/19 03:20 PM
Your good on using those heads on your short block without adding the extra holes up
Mopar added the extra holes for exhaust valve cooling in the 440-3 motor home motors only, none of the other H.D. motors had them shruggy
Re: 440 Motorhome head swap [Re: toyotajeep] #2608683
01/18/19 05:52 PM
01/18/19 05:52 PM
What I would do is measure how far in the hole they are & a righteous guesstimate on the head CC's to see what you have now & also to see the diff between the 2 gasket types just for fun. United machine and Wallace racing have user friendly CR calculators. Post how it turns out.
Re: 440 Motorhome head swap [Re: toyotajeep] #2608979
01/19/19 02:11 PM
01/19/19 02:11 PM
Southern Oregon
Southern Oregon
I believe that they were .170 in the hole. I don't have the engine here now. Whatever it is, it is the typical 7:2.1 compression scene or close to it.
My whole purpose for using the heads is that they are better than the regular heads I have on hand.
That and practice porting the bowls on and playing with my guide tools etc. Learning....
As an aside, how common are leaks with the steel shim gaskets? Just OEM parts cleaned, copper coated and torqued? Are leaks generally an issue?
Re: 440 Motorhome head swap [Re: toyotajeep] #2609063
01/19/19 05:41 PM
01/19/19 05:41 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
I have never had a problem with leaks using the steel gaskets on an iron head. Plus, I usually don't coat my gaskets. My thoughts were that Chrysler made millions of big blocks and used stamped steel gaskets on them. If it was good enough for Ma Mopar, it's good enough for me.
Re: 440 Motorhome head swap [Re: toyotajeep] #2609156
01/19/19 10:46 PM
01/19/19 10:46 PM
I use two or three coats of silver or aluminum rattle can paint to seal steel shim head gaskets on non decked and or smooth surface heads up scope
Re: 440 Motorhome head swap [Re: toyotajeep] #2609170
01/19/19 11:36 PM
01/19/19 11:36 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
I ran 213 motorhome heads on my 470 without issue for what it's worth.
Re: 440 Motorhome head swap [Re: toyotajeep] #2609839
01/21/19 01:19 PM
01/21/19 01:19 PM
Chicago
PurpleBeeper Offline
Chicago
If you plan to deck/re-surface the block, then I suggest you consider drilling the holes into the deck (if you're sure you will be using heads with the extra cooling passages). You would need to find some head gaskets with the extra holes OR possibly drill holes into "regular" head gaskets.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: 440 Motorhome head swap [Re: PurpleBeeper] #2609884
01/21/19 02:54 PM
01/21/19 02:54 PM
For some more info on the above drilling go to www.moparchat.com then scroll down to & click on "circle track chat" then peruse Sanborns' cooling mods that are in a sticky at the top of the page, A long read but worth the time.
Re: 440 Motorhome head swap [Re: toyotajeep] #2610336
01/22/19 11:23 AM
01/22/19 11:23 AM
scratchnfotraction Offline
there are 2 sets of BB #452 heads 1 set has extra cooling passages around the spark plug hole and use the 5/8 hex 'peanut" plugs. AKA-#452 motor home heads.
the other set does NOT have extra cooling ports around plug holes and use a 13/16 hex plug. AKA-#452 car heads.
look at the plug hole, the MH #452 head will have a small machine area around plug hole with a small bump in the casting below plug hole. extra cooling port under bump. hence small plug & machine area. (FYI a 13/16 plug will screw in and work as that is what I found in mine at the start, but not ideal fit looking at head on bench)
it also had head gaskets that blocked those ports on block/head so it worked this way either head from what I can tell.
the car #452 head has a larger machine area around the hole and no bump in the casting.
my 77 440 MH engine had the peanut plug heads and I swapped to a fresh set of car 452 heads 13/16 plugs.
I looked into all that when I swapped heads. no cooling issues with mine.
only time it ran hot was with retard timing. stays at 185* now it tuned.
only way to use those IND/MH heads is to use the raised WP housing and exhaust manifolds.
but you can take the IND/MH 413 short block bore & stroke to a 426 wedge as that is the ticket for using one of those IND/MH engines to get a cheap 426 wedge/max wedge clone.
Re: 440 Motorhome head swap [Re: toyotajeep] #2610403
01/22/19 01:59 PM
01/22/19 01:59 PM
Southern Oregon
Southern Oregon
I'm only using these heads because they are in better shape than the other ones. I really am not interested in drilling holes etc. I think it will work with what I have. Kind of practice heads if you will.
There are indeed some differences between these heads and the regular ones. I have to use different plugs etc. but it is mildly inconvenient.
No machining. Just going to run them as is.
