340 dist. drive removal. Whats your method?? #260817
03/21/09 03:31 PM
03/21/09 03:31 PM
Medford OR
FrankenScamp Offline OP
Medford OR
The intake is on and I just want to prime the system. I know to turn the engine a little at a time and stuff.
I just want some suggestions on how to get it outta there. Thanks!!
Re: 340 dist. drive removal. Whats your method?? [Re: FrankenScamp] #260818
03/21/09 03:35 PM
03/21/09 03:35 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Stick a screwdriver in the slot and turn the gear. It should back out enough to grab it with a pair of needle nose pliers and lift it out.
Re: 340 dist. drive removal. Whats your method?? [Re: stumpy] #260819
03/21/09 03:38 PM
03/21/09 03:38 PM
Medford OR
Medford OR
the gear seems to be too big to fit out with the needles nose holding onto it. thought about putting something sticky on the top and pulling it out like that...maybe time to go buy a magnet??
Thanks Stumpy.....
Re: 340 dist. drive removal. Whats your method?? [Re: FrankenScamp] #260820
03/21/09 04:12 PM
03/21/09 04:12 PM
Medford OR
Medford OR
Well I got it out with one of my pick tools.
Thanks. Shawn
Re: 340 dist. drive removal. Whats your method?? [Re: FrankenScamp] #260821
03/21/09 04:17 PM
03/21/09 04:17 PM
Kentucky, USA
derekeh Offline
derekeh  Offline
Kentucky, USA
I used a magnet on mine. Pulled that sucker right outta there!
Re: 340 dist. drive removal. Whats your method?? [Re: derekeh] #260822
03/21/09 05:03 PM
03/21/09 05:03 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
I have always backed them off with a screwdriver and pulled them up with a magnet.
Re: 340 dist. drive removal. Whats your method?? [Re: T2R9] #260823
03/21/09 07:17 PM
03/21/09 07:17 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've used a pair of long-reach needle nose pliers but it takes a little effort to see in there; I don't have a magnet strong enough to just pull the thing out, but I'll try to find one, as that's a good idea.
Re: 340 dist. drive removal. Whats your method?? [Re: FrankenScamp] #260824
03/21/09 08:00 PM
03/21/09 08:00 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
I've used a piece of thin wire before, about 2' long, doubled it over to make a loop, draped that over the gear, twisted a few times and lifted it out.
Re: 340 dist. drive removal. Whats your method?? [Re: MoparJoe] #260825
03/21/09 08:20 PM
03/21/09 08:20 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
I have a pair of expanding ring pliers that work great.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: 340 dist. drive removal. Whats your method?? [Re: MoparJoe] #260826
03/21/09 08:20 PM
03/21/09 08:20 PM
Medford OR
Medford OR
I thought about trying to "lasso" it out of there as well.
Re: 340 dist. drive removal. Whats your method?? [Re: FrankenScamp] #260827
03/22/09 08:42 AM
03/22/09 08:42 AM
Mass
dgc333 Offline
dgc333  Offline
Mass
Tow large flat blade screw drivers in the slot and squeeze the handles together, this wedges the blades in and you can lift it right out.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: 340 dist. drive removal. Whats your method?? [Re: FrankenScamp] #260828
03/22/09 10:32 AM
03/22/09 10:32 AM
Tampa, Fl.
tampacuda69 Offline
tampacuda69  Offline
Tampa, Fl.
A piece of wire clothes hanger bent to fit under gear, can be lifted up ang grabed easily.
Re: 340 dist. drive removal. Whats your method?? [Re: tampacuda69] #260829
03/22/09 10:39 AM
03/22/09 10:39 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I have used thin gauge electrical wire and made a loop and pulled it up. Mike
Re: 340 dist. drive removal. Whats your method?? [Re: tampacuda69] #260830
03/22/09 11:44 AM
03/22/09 11:44 AM
that's what I do if rotating it w a big screwdriver doesn't do it.
Re: 340 dist. drive removal. Whats your method?? [Re: dgc333] #260831
03/22/09 12:02 PM
03/22/09 12:02 PM
Medford OR
Medford OR
Good one!!
