Re: Milodon External oil system simple Q: [Re: ZIPPY] #2606969
01/15/19 03:32 PM
01/15/19 03:32 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Almost got it, just need to mount the pickup.
First tried to go under the pump but that didn't work out with the filter in place. I'll leave the line a little on the long side so it can be trimmed of needed after it's installed in the car. Like so many other things it doesn't look like much but alot of thought went into it.
Rich H.
Esse Quam Videri
Re: Milodon External oil system simple Q: [Re: ZIPPY] #2607000
01/15/19 04:30 PM
01/15/19 04:30 PM
Cab_Burge Online work
Cab_Burge  Online Work
Is that fitting your using on the block or the oil pump?
If on the block have you look closely at that fitting on the front of the block to see if you really want to use it?
If not please do so before you finish making your new oiling system twocents scope
Re: Milodon External oil system simple Q: [Re: ZIPPY] #2607032
01/15/19 05:16 PM
01/15/19 05:16 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
It's the one on the front of the block which then goes to the oil pump inlet. I've spent some time looking at it. Impressions:
I'm aware it's more restrictive than running hose directly into the pump via a special pump/special cover arrangement, but I also see it as an improvement over the internal pickup I was going to use previously.
That oil passage does have a reduced ID + one 90 degree turn before oil enters the pump, but I don't feel either of these things will create any issues.
I do plan on removing the restrictive hard 90 fitting from the pickup, and will use a regular bulkhead fitting + a 90 degree hose end there instead.
Re: Milodon External oil system simple Q: [Re: ZIPPY] #2607312
01/16/19 01:48 AM
01/16/19 01:48 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
The teflon hose requires the special PTFE fittings.
Re: Milodon External oil system simple Q: [Re: ZIPPY] #2607473
01/16/19 02:06 PM
01/16/19 02:06 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Scratch that, won't work due to lower rad hose interference.
Time for plan C.
Thanks for the advice, all.
Re: Milodon External oil system simple Q: [Re: ZIPPY] #2607550
01/16/19 03:44 PM
01/16/19 03:44 PM
I use the cast aluminum Milidon pump with the fitting for the second oil pick up cast into the front of it up scope
Re: Milodon External oil system simple Q: [Re: ZIPPY] #2607579
01/16/19 04:13 PM
01/16/19 04:13 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Time for plan C.
It is tight down there. I welded on -20 weld on bungs & use -20 AN hose & fittings on my water pump housing to rad connections.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Milodon External oil system simple Q: [Re: 6PKRTSE] #2607592
01/16/19 04:29 PM
01/16/19 04:29 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Time for plan C.
Yeah, that would definitely work!
Remote electric water pump would sure work....I'd probably love that...Not sure I could bring myself to do that without the usual belt drive to go with it, but, it would be cool.
It all adds up and I don't want to out-trick myself just yet. I'll hit the "easy" button on this and will go with plan C (pump cover with bulkhead fitting sticking out). That should give me nicer routing and (very slightly) less restriction, and can keep the other things a little closer to stock for the time being.
Re: Milodon External oil system simple Q: [Re: ZIPPY] #2607708
01/16/19 08:35 PM
01/16/19 08:35 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I use 2 lines with one facing forward.I also used pre filters as Jimi Vignogna told me to. smoke
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Milodon External oil system simple Q: [Re: ZIPPY] #2607759
01/16/19 09:54 PM
01/16/19 09:54 PM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Time for plan C.
Hey Zippy,
Mine has the front line and I also use a factory style waterpump housing. Lower rad hose is tight but it does clear.
Ron
Re: Milodon External oil system simple Q: [Re: firefighter3931] #2607833
01/16/19 11:50 PM
01/16/19 11:50 PM
hemi-itis Offline
hemi-itis  Offline
Time for plan C.
Hey Zippy,
Ron
So do I,sure gets crowded down there!
Re: Milodon External oil system simple Q: [Re: ZIPPY] #2608058
01/17/19 02:08 PM
01/17/19 02:08 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Ron, I can "make it work" with a hard 90 bulkhead fitting sticking out of the block but I can't route the hose quite the way that I wanted. Developed a preference for a straight bulkhead fitting and 120 hose end, which takes up a lot more room, and that's what killed the idea.
Al, the world block external oil pickup hole is even closer yet to the w/p. It's workable but I feel I'd be forced to use somewhat less than ideal plumbing to use it. Since I'm only going to have one pickup line I decided it's best if it is as unobstructed as possible.
Re: Milodon External oil system simple Q: [Re: ZIPPY] #2608064
01/17/19 02:26 PM
01/17/19 02:26 PM
AndyF Offline
AndyF  Offline
You can switch to passenger side inlet water pump and swap radiators. I'm not a big fan of the passenger side inlet since then it gets crowded on that side with the alternator and the TDC pointer but it can be done.
Re: Milodon External oil system simple Q: [Re: ZIPPY] #2608066
01/17/19 02:28 PM
01/17/19 02:28 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Personally I would dump that oil pump and go with the newer milodon billet - A Hemi will move more oil volume than a wedge - hence the reason for two lines in - here is how we routed the front line. Milodon makes two covers for the pump depending if you are using the stock mounts or not - either way it gets real crowded down there by the oil filter
Re: Milodon External oil system simple Q: [Re: ZIPPY] #2608069
01/17/19 02:29 PM
01/17/19 02:29 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Yeah I never really liked that right side inlet either.
Re: Milodon External oil system simple Q: [Re: DoubleD] #2608071
01/17/19 02:35 PM
01/17/19 02:35 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
An upgraded pump is a possiblity, and simple enough to change later if I'm not happy with the Melling.
The hard 90 coming out of the block will definitely work, but I decided I want to try routing the hose differently.
Re: Milodon External oil system simple Q: [Re: ZIPPY] #2608088
01/17/19 02:59 PM
01/17/19 02:59 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I've been using the black nylon hose for a few years with no issues. I also use on internal spring when it is going to be making tight turns for sure if not always
