Friction modifer for cone sure-grip?
#2607542
01/16/19 03:34 PM
01/16/19 03:34 PM
Posts: 741 Citrus Heights, CA
69_Swinger
Citrus Heights, CA
I recently acquired a 7-1/4" rearend for my son's /6 Valiant that has a "cone" type sure-grip. I'm familiar with the "clutch" suregrips, and understand that the friction modifier is required for the clutches to work properly. is this also true for the "cone" type? I haven't had one of these apart before. Thanks!
67 Valiant /6 2-door (Father/Daughter project)
Re: Friction modifer for cone sure-grip?
[Re: 69_Swinger]
#2607570
01/16/19 04:00 PM
01/16/19 04:00 PM
Posts: 25,836 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Yes, same additive required for the cone-type.
[Re: 69_Swinger]
#2608282
01/17/19 09:40 PM
01/17/19 09:40 PM
Posts: 959 Chicago
PurpleBeeper
Chicago
I believe "Ford" brand is recommended by several people I've seen & some parts stores carry it (Ford dealers too obviously)
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: MasterDeBaTeR !]
#2608419
01/18/19 02:45 AM
01/18/19 02:45 AM
Posts: 954 garnett kansas
rhad
garnett kansas
someone told me years ago that there was only one manufacturer of the stuff and company's had their own packaging for it
my ladder of success is missing some rungs
[Re: 69_Swinger]
#2608755
01/18/19 08:51 PM
01/18/19 08:51 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Whale oil, not skunk oil. Used to come from whales.
[Re: Supercuda]
#2608809
01/18/19 11:17 PM
01/18/19 11:17 PM
Posts: 21,827 Kirkland, Washington
Pacnorthcuda
Whale oil, not skunk oil. Used to come from whales. Yep....and contrary to a sometimes seen myth, it wasn't whale Sperm!!! It came from Sperm Whales!
[Re: PurpleBeeper]
#2609737
01/21/19 02:57 AM
01/21/19 02:57 AM
RapidRobert
I believe "Ford" brand is recommended by several people I've seen & some parts stores carry it (Ford dealers too obviously) thats what I heard too. dont have a part #.
[Re: RapidRobert]
#2614090
01/29/19 03:46 PM
01/29/19 03:46 PM
dogdays
#2614095
01/29/19 03:54 PM
01/29/19 03:54 PM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
OK guyz .... other than draining out and filtering old SKUNK OIL out of a junk yard car - WHICH I HAVE DONE some years ago - is the only GOOD and reliable additive is from Generous Motors? Yup..Delco part # 992694. I use it in all my Sure grips. But still does not make it a "posi" LOL!! I put it in first then the gear oil and run the car on the hoist (or jack stands) at idle for ten minutes. This ensures the conditioner goes through all the clutches.
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
[Re: 69_Swinger]
#2614543
01/30/19 01:04 PM
01/30/19 01:04 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
[Re: dogdays]
#2614815
01/30/19 11:24 PM
01/30/19 11:24 PM
Posts: 4,315 Prospect, PA
BSB67
Prospect, PA
I do not believe that Fiat-Chrysler or GM or Ford manufacture their own. They are probably all made by the same chemical company like CRC, which uses K&W as a brand name for their friction modifier for limited slip differentials.
Most of the parts in an automobile are made by suppliers. I see no reason to believe that the goop that they sell is made by the "car manufacturers" either. MAYBE it is made to their specification by a supplier. And maybe the supplier gets their specification and comes back with a bid, but says "if we could substitute this we could save you 17%" and so what you buy in a Mopar or Motorcraft or Delco can is actually the same stuff.
R. Always some exceptions, but generally, this sums it up.
[Re: 69_Swinger]
#2614820
01/30/19 11:33 PM
01/30/19 11:33 PM
NachoRT74
Valencia, España
yeah, that's exactly why I ask... there is not a reason to suggest any brand being same product, but really unmatches in my mind on a Mopar board somebody advising to buy any other diff from Mopar ( GM or Ford ) labeled product just by default being same price rate and same product itself LOL. It makes me a brain short circuit LOL. To each own, but is weird at least
[Re: dogdays]
#2614822
01/30/19 11:34 PM
01/30/19 11:34 PM
Posts: 595 Nashville, Tennessee
Tempest
R. I can assure you this is the case after 34 years in the chemical business. NONE of the auto mfg's make ANY chemical products anymore! They are private labeled. However, this was not always the case in the 1960's. Mopar did mfg own their own chemical operations in Trenton MI.
