Racepak O2 sensor
#2607298
01/16/19 01:09 AM
01/16/19 01:09 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Is there an O2 sensor that I can buy at my local auto parts store that will work Plug & Play. Thanks ahead of time
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: Racepak O2 sensor
[Re: WHITEDART]
#2607432
01/16/19 12:59 PM
01/16/19 12:59 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
When I get down to my garage I will try to remember to get you the PN. If your presses for time you can call Racepak and they will give you the PN.
[Re: WHITEDART]
#2607721
01/16/19 08:53 PM
01/16/19 08:53 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
For future reference for anyone that needs to replace the sensor.
Bosch 17018 LSU 4.2 5 Wire Wideband Oxygen Sensor Bosch OE # 0 258 007 018 ( 0258007018 ) AEM # 30-2001 Autometer # 2243 FAST # 170408 Dynojet Wideband Commander # 48292001 GM # 12575657 AC/Delco # 213-1572 PLX Devices # Type B Motec # 57005 Bigstuff3 BS3 JMI-003-001 Subaru # 22641-AA000
[Re: Al_Alguire]
#2607729
01/16/19 09:09 PM
01/16/19 09:09 PM
WHITEDART
bean town ....Ca
Thanks I'm going to screenshot this page and save it for sure
[Re: WHITEDART]
#2607731
01/16/19 09:11 PM
01/16/19 09:11 PM
hemi-itis
While we're here,,,Al, how long do these sensors generally last?? Leaded fuel supposedly make these sensors out of whack
[Re: WHITEDART]
#2607737
01/16/19 09:20 PM
01/16/19 09:20 PM
Al_Alguire
Las Vegas
Leaded fuel will certainly eventually kill them. We keep a couple spares in the trailer actually.
[Re: WHITEDART]
#2607929
01/17/19 03:19 AM
01/17/19 03:19 AM
Al_Alguire
Las Vegas
We use 8 We usually have at least one go dead every year
[Re: WHITEDART]
#2607936
01/17/19 04:01 AM
01/17/19 04:01 AM
Al_Alguire
Las Vegas
Readings are either WAY off or they just flatline
[Re: WHITEDART]
#2608077
01/17/19 02:41 PM
01/17/19 02:41 PM
Al_Alguire
Las Vegas
They are plug and play. A 5 wire sensor, easiest I have found is to use the Bosch number and hopefully the parts guy is smart enough to cross reference the number for you. I believe the OE application for domestic stuff is 02-04 Cadillacs IIRC
[Re: Al_Alguire]
#2608345
01/18/19 12:11 AM
01/18/19 12:11 AM
WHITEDART
bean town ....Ca
Thanks guys went up to the local auto parts and grabbed a Bosch O2 sensor part number provided by Al was a Plug & Play also saved a few bucks..
[Re: WHITEDART]
#2608652
01/18/19 04:20 PM
01/18/19 04:20 PM
Al_Alguire
Las Vegas
I think the AEM sensor is also the same sensor Racepak uses..I usually pay $50-55 for the Bosch sensor. Shop around most every parts store carries them.
[Re: Biginchmopar]
#2609026
01/19/19 04:21 PM
01/19/19 04:21 PM
hemi-itis
Thanks guys went up to the local auto parts and grabbed a Bosch O2 sensor part number provided by Al was a Plug & Play also saved a few bucks.. Called a few local parts stores to argue about what car it's for...... After getting them to look up the PN# they are all in the $75 range I see them online for $45 + ship.
