Re: Do You Run A Pinion Snubber or Other Aftermarket Device?
[Re: GoodysGotaCuda]
#2606405
01/14/19 01:02 PM
01/14/19 01:02 PM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
Trim it down to length, and/or increase springrate. Depending on the amount the car is lowered, you really want a snubber, simply to prevent the driveshaft from digging into the tunnel during heavy acceleration (and maybe some extra load in the back like people. Ask me how I know ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif)
[Re: BigBlockMopar]
#2606458
01/14/19 02:39 PM
01/14/19 02:39 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Trim it down to length, and/or increase springrate. Depending on the amount the car is lowered, you really want a snubber, simply to prevent the driveshaft from digging into the tunnel during heavy acceleration (and maybe some extra load in the back like people. Ask me how I know Thanks. First thing I need to do is validate that it is, in fact, touching during normal operation.
#2606461
01/14/19 02:55 PM
01/14/19 02:55 PM
Posts: 22,732 Bitopia
jcc
Bitopia
I assume the SS springs have an arch while at rest? If so, I'd concentrate more on replacing/optimizing the leaf spring package and removing/reducing the lower blocks, before spending much time and effort on the snubber solution.
#2606607
01/14/19 08:41 PM
01/14/19 08:41 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Floor pan will be shiny where it hits, assuming you drive it regular.
#2606733
01/15/19 01:02 AM
01/15/19 01:02 AM
Supercuda
About to go away
About to go away
up yours
Well, I am used to 100k+ miles so it'll be shiny by then, lol. I don't think I ever actually measured clearances but that sound like what I remember.
#2607017
01/15/19 05:02 PM
01/15/19 05:02 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
I run a stock snubber. actually slightly raised up with a few washers and slightly longer bolts... my Challenger is lowered.. snubber does occassionaly hit (chalk marks on top of the rubber) but nothing serious to be concerned about for me.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
#2621494
02/15/19 12:29 AM
02/15/19 12:29 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Use the front segment of the leaf springs to control the pinion from rising towards the floor during launch and acceleration. A pinion snubber is a crutch for weak leaf springs.
Trim the rubber so there is no metal to metal contact. This will be a challenge on a lowered car but if it's still hitting you may need stronger springs and or shocks.
#2622537
02/17/19 02:53 PM
02/17/19 02:53 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
I take the off and never noticed any difference... the adjustable pinion type snubbers are so tall you can’t even drive the car with them on lowered springs
A new iron curtain drawn across the 49th parallel
