Re: B1 heads, who is the best porter? What do yours flow?
[Re: Cab_Burge]
#2606813
01/15/19 10:20 AM
01/15/19 10:20 AM
Posts: 4,701 On the parachute mount
n20mstr
Scott Brown/Modern or Best Machine. Cant go wrong with either one of these guys, there are a lot more out there also that are good.
....BAD A$$ STREET CAR.....
[Re: Cab_Burge]
#2606960
01/15/19 03:12 PM
01/15/19 03:12 PM
Posts: 19,391 Las Vegas
Al_Alguire
Las Vegas
Slawko ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) CFE has a CNC Program or did at one point that is pretty good.
[Re: Cab_Burge]
#2608200
01/17/19 06:32 PM
01/17/19 06:32 PM
Posts: 248 near St Petersburg, FL
Lifsgrt
Hey Cab, the B1MC heads I bought used from Tom in Utah were ported by a guy named Gold at Fastlane Machine Inc at 801-226-5511 also in Utah. Best Machine built my B-block (THE BLOCK) 499" Bonneville bullet and checked out/freshened these heads in the process. I have flow sheets, but don't have time to figure out how to attach. I got the sheet with the heads flowed on a 4.400 bore, and the numbers were very close but slightly lower than the numbers Best Machine got on a 4.500 bore. They flow I357 E243 @ .500, I425 E299 @ .700. and I454 E319 @ .900. Hope this helps. PM me and I can send flow sheets.
B3 1969 Charger R/T SE, 440/727 with 3:91s running 11.07@120
