Re: The Best Wideband Air Fuel Gauge
[Re: Cab_Burge]
#2606511
01/14/19 04:44 PM
01/14/19 04:44 PM
Posts: 714 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
If your going to test alcohol carbs get the good NTK sensors, not Bosch Why? I run both NGK/NTK and Bosch and the only difference I can see is the NGK hold up to leaded fuels a little better. On methanol (which is about 25% of my customers) I see no difference. Joe
Without Data, you’re just another guy with an opinion.
[Re: ScottSmith_Harms]
#2606554
01/14/19 06:32 PM
01/14/19 06:32 PM
Posts: 4,866 North of Detroit
HemiDart68
North of Detroit
Innovate lm2 works great as mentioned above. If you read reviews the only people that usually have issues are using the cigarette lighter plug. I hooked it direct to my car 12 volt wiring for clean power with a plug. Nice unit.
In God we trust, all others pay cash.
www.lightnens.com (Home of the world's fastest Paint Job)
#2606565
01/14/19 06:56 PM
01/14/19 06:56 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Scott, If you're considering the Innovate products, then see if a setup with more channels might be a better investment. Something like the SSI-4 or LMA-3 combined with a logger and WBO2. Having MAP, TPS, and rpm with the WBO2 will give a most complete picture. https://www.innovatemotorsports.com/products/pl1.phpYou can set up an older laptop to watch everything real time as well as logging. Before buying, download Logworks and see if you like the way it feels and learn its quicks. https://www.innovatemotorsports.com/support.phpIf you need sample/examples in addition to what may come in the download, there's some at RFS as attachments. Or just ask, and folks can e-mail you theirs. Innovate stuff has a learning curve and the instructions are more like what you find in industry where they assume the buyers have some datalogging background. So its not for everyone, but it is good product for the price range.
[Re: Twostick]
#2606663
01/14/19 10:57 PM
01/14/19 10:57 PM
dartman366
Mt. Vernon, Ohio
I have had the Innovate LM-2 for several years and am in the process of getting the MTX-L guage and PL-1 pocket logger so I dont have to keep the LM-2 in the car un mounted, as said above they assume you have prior experience with this type of electronics,,I don't and it has taken me a while to learn the basics,, the new equipment will make things a little easier and a tidier set-up.
#2606819
01/15/19 10:54 AM
01/15/19 10:54 AM
Posts: 8,022 Tulsa OK
Bad340fish
Tulsa OK
You probably know this but you will want to make sure you have plenty of pipe after the 02 sensor or else it can pull some fresh air back in and skew the readings.
My car has full exhaust but it has exhaust dumps not to far from the 02 sensors. When they are open the 02s read full lean until at least 2500RPM or so. My car also has a big roller cam with lots of overlap which I am sure doesn't help. They function just fine in the mid range and above but don't give any data at idle and low engine speeds.
68 Barracuda Formula S 340
[Re: Mattax]
#2606821
01/15/19 11:00 AM
01/15/19 11:00 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
One thing I just realized is that being on a test stand there will be no load. May limit what can be learned MY THOUGHT EXACTLY
JAKES AUTOMOTIVE
#2607281
01/16/19 12:26 AM
01/16/19 12:26 AM
Mattax
Phila. Pa.
Yes Mattax, pretty much will be just to get more accurate mixture adjustments, I already have a vacuum gauge and a tach which works just fine but going to the next level never hurts . I'll likely use it to tune my cars too so it will get used elsewhere as well. A CO meter might provide a better indication AFR than a WBO2 when working on idle. Don't get me wrong, its great to be able to log Vac, rpm and AFR (or lamda). I plan to add TPS at some point. But left over CO seems to be less subject to variations in combustion temperature and other phenonmenon that can fool an AFR based on left over O or O2
