Slip Plate on exhaust manifolds. #2606162
01/13/19 10:08 PM
01/13/19 10:08 PM
GMP440 Offline OP
GMP440  Offline OP
A while back there was a topic about what pain to use on exhaust manifolds. Someone mentioned about Slip Plate graphite coating.
Maybe someone with experience with using this can chime in.
How long does it last? Does it come of easy if you touch it?
Here is the the link that shows Napa sells this. Is this the
correct Slip Plate to use on exhaust manifolds? Thanks.
https://www.napaonline.com/en/p/BK_33203
Re: Slip Plate on exhaust manifolds. [Re: GMP440] #2606216
01/13/19 11:55 PM
01/13/19 11:55 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
There was a post about it either here or on FBBO or both. Yes the link you provided is the correct stuff. I know a guy that used it on his manifolds and it held up about a year that I know of so far. I also just applied it to mine after having them blasted. It is simple to use just spray a few light coats and after a good dry time just wipe the part down with a clean rag and the part will look like clean fresh metal. I haven't started my engine yet but plan to this week. Hopefully with breaking in the cam and the paint burning off on top of it all will workout.
I also just did the procedure to my master cylinder that just came back from White Post, I had then send it back after rebuild in bare metal.
Hope this helps
Ron
Re: Slip Plate on exhaust manifolds. [Re: GMP440] #2606253
01/14/19 01:05 AM
01/14/19 01:05 AM
Kentucky
fc7freak Offline
fc7freak  Offline
Kentucky
I have used Slip Plate on two different cars. Really works great. You will be able to rub some off on your hands but not a problem.
Re: Slip Plate on exhaust manifolds. [Re: GMP440] #2606339
01/14/19 09:54 AM
01/14/19 09:54 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Re: Slip Plate on exhaust manifolds. [Re: RJS] #2606537
01/14/19 05:50 PM
01/14/19 05:50 PM
Nanuet, NY
johntpr Online content
johntpr  Online Content
Nanuet, NY
Hope this helps
Ron
Wow that looks incredible Ron !
69 Daytona 4 speed
Re: Slip Plate on exhaust manifolds. [Re: johntpr] #2606673
01/14/19 11:18 PM
01/14/19 11:18 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Hope this helps
Ron
Thanks John, your always the gentleman!!!
