What brand/type of trans and brake fluid? #2605331
01/12/19 11:48 AM
01/12/19 11:48 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
What brand/type of trans (727) and brake fluids (manual) are you running in your Mopar?
Re: What brand/type of trans and brake fluid? [Re: vinnyd76] #2605345
01/12/19 12:47 PM
01/12/19 12:47 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Any brand +4 or HyGard hydrostat fluid in the tranny and DOT 5 for the brakes.
Master, again and still
Re: What brand/type of trans and brake fluid? [Re: vinnyd76] #2605365
01/12/19 01:46 PM
01/12/19 01:46 PM
Kirkland, Washington
Pacnorthcuda Offline
Castrol DOT 4 brake fluid, but I wouldn't hesitate to use other brands of DOT 4. Don't currently own a 727, but when I did, Valvoline type F, but other brands would be acceptable too.
I'm pickier about brands when it comes to other fluids, but not those.
Re: What brand/type of trans and brake fluid? [Re: vinnyd76] #2605378
01/12/19 02:01 PM
01/12/19 02:01 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I`m going with Dot 5 this time around in my current build since everything will be new. I have it in another car I own and I have had no issues. I used Type F last time in my 904 but I`m not sure what I am going to use this time. Looking to see what others recommend here.
Re: What brand/type of trans and brake fluid? [Re: mopars4ever] #2605397
01/12/19 02:39 PM
01/12/19 02:39 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
I was also told to use DOT 5. I was advise DOT 5 does not damage the paint in the event there is an accident and fluid leaks/spills.
Re: What brand/type of trans and brake fluid? [Re: vinnyd76] #2605408
01/12/19 03:01 PM
01/12/19 03:01 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I always hear Type F for firmer shifts but not best for the 727.
I go with what trans shop owner of over 30 years here in town tells me to use in my 727 for best durability; Dex/Merc.
Facts are stubborn things.
Re: What brand/type of trans and brake fluid? [Re: vinnyd76] #2605437
01/12/19 03:27 PM
01/12/19 03:27 PM
tucson az
frank Offline
frank  Offline
tucson az
I use regular old dot 3 fluid for brakes. I've never had any brake issues and my cars never failed to stop. It was recommended to me from Dave at Protrans to use Type F (any brand) in the 727 he built for my Charger. In the past I've used both the Dodge recommended fluid and Type F in 727 trans. Again I've never had a fluid related issue in any 727 in any of my cars or trucks that had a 727
Re: What brand/type of trans and brake fluid? [Re: vinnyd76] #2605442
01/12/19 03:36 PM
01/12/19 03:36 PM
md
mopars4ever Offline
mopars4ever  Offline
md
That`s the main reason I am using it this time around being I will have new paint.
Re: What brand/type of trans and brake fluid? [Re: vinnyd76] #2605650
01/12/19 11:44 PM
01/12/19 11:44 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
what ever walmart sells...
Tony
70 AARCuda Vitamin C
Re: What brand/type of trans and brake fluid? [Re: 70AARcuda] #2605898
01/13/19 02:57 PM
01/13/19 02:57 PM
moparx Offline
moparx  Offline
what happens to a 727 [and converter] if one switches to the [any old brand] type F from a synthetic fluid ? i have never had a failure from using type F in any 727 or 904, [and even using dex 3 in the later front drives that are supposed to use +4] but i have absolutely no experience with synthetics.
just a drain and refill, not a fresh rebuild, and there will still be some synthetic that won't be totally drained.
beer
Re: What brand/type of trans and brake fluid? [Re: vinnyd76] #2605929
01/13/19 03:49 PM
01/13/19 03:49 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Use walmart brand Type F. You can buy other brands but there isn't much reason to.
Re: What brand/type of trans and brake fluid? [Re: vinnyd76] #2606198
01/13/19 11:18 PM
01/13/19 11:18 PM
Mass
charge70 Offline
charge70  Offline
Mass
For brake fluid I use DOT 5.Like others said no paint problems if there is any spillage.The ATF I use is whatever the local parts stores stock but I was told by John K.on this board was to use a 50/50 mix of Dexron and Type F.I've been doing it that way for years without any problems.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: What brand/type of trans and brake fluid? [Re: charge70] #2606492
01/14/19 04:08 PM
01/14/19 04:08 PM
Berwyn, IL
challenger70 Offline
Berwyn, IL
I use this Penzoil as recomended by Cope.
http://coperacingtranscom.ipage.com/?product_cat=trans-fluid
I also have switched to DOT 5 without ant problems...yet.
https://www.summitracing.com/parts/wil-2...BSABEgLcv_D_BwE
"high performance brake fluid"
"Wilwood does not recommend using DOT 5 fluid in any racing applications." LOL
Re: What brand/type of trans and brake fluid? [Re: vinnyd76] #2606753
01/15/19 01:38 AM
01/15/19 01:38 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
There is no letter T in the word DEXRON. WTH is dextron? Some sort of 80's techno fluid?
Cope and his home built trans are pretty comical. Had a friend spec out a complete trans for a 10 second racecar. Burnt up in 2 days at the track. Cope was like, "Oh I had a bad run of valve bodies but thought I had those fixed". Gee thanks CRT!
Re: What brand/type of trans and brake fluid? [Re: NANKET] #2606854
01/15/19 12:19 PM
01/15/19 12:19 PM
Berwyn, IL
Berwyn, IL
Good to know, I shall keep that in mind.
Re: What brand/type of trans and brake fluid? [Re: challenger70] #2607519
01/16/19 03:13 PM
01/16/19 03:13 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I hope so you awful person!!!!!
