Small Block Oil Pan Gaskets
#2605347
01/12/19 12:55 PM
01/12/19 12:55 PM
Posts: 1,412 Johnstown
69dart
Johnstown
I'm building my first small block - 340. Well technically its already rebuilt but I wanted to pull the pan and check it out. Anyway I learned 360 oil pan gaskets are different than 340 oil pan gaskets. I ordered the 1 piece gasket - https://www.jegs.com/i/JEGS/555/210495/10002/-1 but it didnt fit. So whats the best 340 oil pan gasket?
Re: Small Block Oil Pan Gaskets
[Re: 69dart]
#2605361
01/12/19 01:32 PM
01/12/19 01:32 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
Call Greg at Superformance gaskets. I use his gaskets and have never been disappointed with service or gaskets. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 69dart]
#2605384
01/12/19 02:10 PM
01/12/19 02:10 PM
RapidRobert
As you know it is the rear "half moon" that is different. can you alter/change that part for the 318/340 black rear seal part?
[Re: fourgearsavoy]
#2605441
01/12/19 03:33 PM
01/12/19 03:33 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
Call Greg at Superformance gaskets. I use his gaskets and have never been disappointed with service or gaskets. Gus Yes Greg makes good stuff!
68 Barracuda Formula S 340
