Racing Class only allows iron heads - best option for LA #2605074
01/11/19 07:02 PM
01/11/19 07:02 PM
St. Charles, IL
roadracecuda Offline OP
St. Charles, IL
All-
I have a 67 Barracuda that I road race with different sanctioning bodies in the midwest. They are coming down hard on certain 'non-period' car mods now. I have ported Edlebrocks on my 340 currently and have been given a grace period to replace them with iron heads before I will be failed at tech and not allowed to run. So, I am going to set the current engine aside for my 71 Scamp project and start fresh. I have a 340 block, Milodon 340 road race oil pan, and McLeod lightweight clutch and flywheel that will port over to the new engine otherwise I'm starting over. Strokers are out (yes, they can check displacement at the track). I hate to lose the Eddys (CNC ported and flowed around 300 @ .600 lift - current cam/rockers net about .610 lift) but it is what it is. Crank, rods, pistons, and cams are open (as long as the stroke is factory). Roller rockers are ok but not roller cams. My big question is the heads. The engine will spend most of its time between 4500 and 7500 rpm. I know people have gotten the same or better flow numbers porting W2s as I saw on my Eddys - is that the best / only choice? Yes, I know that means intake, headers, and valvetrain need to change and that's not the end of the world. Since the heads are where I'm shackled the most I figured I'd start at the top of the engine and work my way down as far as putting a package together. The goal would a comparable (albeit heavier) version of what I have now - a reliable long block putting out something in the 450hp range. I'd take more for sure but I'd rather build something with a little more safety factor (ie - not wound to the hairy edge). Our race weekend usually nets between an hour and two hours of track time and I typically get 6-8 events (2 seasons) between freshening. Thanks in advance for the input.
1967 Barracuda Fastback Vintage Road Racer
1971 Scamp
2015 Challenger
1998 Ram 2500 CTD
Re: Racing Class only allows iron heads - best option for LA [Re: roadracecuda] #2605077
01/11/19 07:07 PM
01/11/19 07:07 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Racing Class only allows iron heads - best option for LA [Re: roadracecuda] #2605080
01/11/19 07:13 PM
01/11/19 07:13 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Stock magnum heads can put out 400hp untouched.
Don't be the exception.
Re: Racing Class only allows iron heads - best option for LA [Re: Supercuda] #2605097
01/11/19 08:00 PM
01/11/19 08:00 PM
Not OE stock (ends look machined/shiney!) but I'm thinking EQ magnums (they are iron) from New Zealand from AAmidwest in Las Vegas. Eric Haugland there is a very easy guy to deal with.
Re: Racing Class only allows iron heads - best option for LA [Re: roadracecuda] #2605109
01/11/19 08:43 PM
01/11/19 08:43 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Obviously, from a power production standpoint the W2’s are going to be hard to beat.
IMM might still be doing something with a cnc ported LAX head, and then you could reuse all the other bits that go along with the E heads.
For road racing, the down side to the LAX’s is they’re pretty heavy.
There’s a post over on FABO right now where Jesse at RAMM built a 340 with a solid cam and some warmed over X heads that made over 450hp.
My old 340 with ported 587’s made 478hp....... so it’s doable with stock heads.
Re: Racing Class only allows iron heads - best option for LA [Re: roadracecuda] #2605126
01/11/19 09:26 PM
01/11/19 09:26 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
What mods to the heads are allowed? This may not apply but 2 of the quickest NHRA Stock eliminator 340's in the country run 051 heads. The Super Stockers run highly modified 308's.
Real Men shift for themselves
Re: Racing Class only allows iron heads - best option for LA [Re: roadracecuda] #2605172
01/11/19 10:50 PM
01/11/19 10:50 PM
I would buy a set of the W2 race heads, not the econo versions tsk and have them ported and set up to flow as much air as they can get without comprising the casting to avoid cracks while road racing twocents
I built a pump gas street and strip 340 with a forged steel 4.0 inch stroke many years ago for a friend of mine and member on here with a set of the race W2 heads mildly ported and polished, it made a little over 514 HP at 5900 RPM on CA pump swill on a stingy DTS engine dyno back in the early 2000s shruggy He drove that motor all over including several of the Hot Rod cruises from CA to back east as well as driving in the one lap around America once work
Those heads did everything my friend wanted and then some, he ran NOS on it also up
Re: Racing Class only allows iron heads - best option for LA [Re: roadracecuda] #2605195
01/11/19 11:31 PM
01/11/19 11:31 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Re: Racing Class only allows iron heads - best option for LA [Re: Supercuda] #2605209
01/11/19 11:55 PM
01/11/19 11:55 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
"They are coming down hard on certain 'non-period' car mods now."
Will the Magnums pass the period visual test?
Re: Racing Class only allows iron heads - best option for LA [Re: roadracecuda] #2605255
01/12/19 01:47 AM
01/12/19 01:47 AM
Rescue CA.
joes68340s Offline
joes68340s  Offline
Rescue CA.
Is this visual or after market. As in iron heads are ok aluminum not. Or is there more to what is acceptable.
Re: Racing Class only allows iron heads - best option for LA [Re: jcc] #2605264
01/12/19 02:15 AM
01/12/19 02:15 AM
St. Charles, IL
St. Charles, IL
I would think so. I think since the Magnums and the W2s have Chrysler casting numbers on them likely nobody would ever say anything. There are so few mopars road racing that nobody is really sure what they are looking at. Doesn't take a genius to spot aluminum vs. cast iron though so that's their big sticking point.
1971 Scamp
2015 Challenger
1998 Ram 2500 CTD
Re: Racing Class only allows iron heads - best option for LA [Re: 1DGEMAN] #2605266
01/12/19 02:20 AM
01/12/19 02:20 AM
St. Charles, IL
St. Charles, IL
Porting, valves, springs, are unlimited.
1971 Scamp
2015 Challenger
1998 Ram 2500 CTD
Re: Racing Class only allows iron heads - best option for LA [Re: fast68plymouth] #2605267
01/12/19 02:22 AM
01/12/19 02:22 AM
St. Charles, IL
St. Charles, IL
I'll check that out. Thanks
1971 Scamp
2015 Challenger
1998 Ram 2500 CTD
Re: Racing Class only allows iron heads - best option for LA [Re: roadracecuda] #2605389
01/12/19 02:15 PM
01/12/19 02:15 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
W2s are probably your best bet. I had some new ones but sold them off a couple years ago.
If interested in the MP Magnum R/T heads, I have some that
I would sell. There used to be a lot of good info on them in the tech archives here.
Just another option to check out. Good luck with the decision 👍
Re: Racing Class only allows iron heads - best option for LA [Re: roadracecuda] #2605414
01/12/19 03:09 PM
01/12/19 03:09 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
If they are looking at the heads, the W2's look more like a standard head. The ends of the Magnums have a different appearance. Maybe all they do is check with a magnet to verify they are iron?
Carl Kessel
Re: Racing Class only allows iron heads - best option for LA [Re: roadracecuda] #2605417
01/12/19 03:11 PM
01/12/19 03:11 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Do they test to find out if they are steel or aluminum or is it just a visual check? Some ancient and hard to find Batten W2's might fill the bill if you could get away with it. The battens at porosity issues so not all are the greatest quality and it took me a long time to find a good set but they exist and they can be ported to flow some really good numbers! Also a candidate are some of the early Diamond W2 heads (which look like the newer Indy heads)/ Both the Battens and the Diamonds have rough cast ends that look like iron heads once painted orange. I know where a really nice set of freshly professionally ported and rebuilt Diamonds can be had if interested. Pics are of Battens
Re: Racing Class only allows iron heads - best option for LA [Re: roadracecuda] #2605425
01/12/19 03:18 PM
01/12/19 03:18 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The Diamonds are a little less convincing but at least they don't look like a big unfinished block of billet aluminum like all the others.
Re: Racing Class only allows iron heads - best option for LA [Re: roadracecuda] #2605427
01/12/19 03:19 PM
01/12/19 03:19 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Original source for the Diamonds
Re: Racing Class only allows iron heads - best option for LA [Re: roadracecuda] #2605467
01/12/19 04:24 PM
01/12/19 04:24 PM
So. Burlington, Vt.
So. Burlington, Vt.
I sure wouldn’t want to spend a bunch of money on heads and valve gear that you know aren’t legal(aluminum), especially when the tech guys have already told you they don’t want them on the motor.
I’d want some clarification on exactly what is and isn’t legal if I used anything other than period correct oe heads.
Re: Racing Class only allows iron heads - best option for LA [Re: fast68plymouth] #2605540
01/12/19 07:15 PM
01/12/19 07:15 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Agreed. I'm not a racer but I would assume there are few things worse than failing tech and turning into a spectator.
