737 HP LA SMALL BLOCK #2604760
01/11/19 01:39 AM
01/11/19 01:39 AM
my own world
theraif Offline OP
theraif  Offline OP
my own world
Let’s cut to the chase: The LA small-block racing engine we’ve been following, built by Michigan’s Valley Performance for the Race Engine Challenge, took home the gold.
Based on average horsepower per cubic inch, the 376-inch underdog surprised and overpowered more than a few LS builders in the event, punching out 1.963 hp for each genuine Mopar cube and claiming the class win.
https://www.hotrod.com/articles/la-engine-kicking-ls-butt-dyno/
Re: 737 HP LA SMALL BLOCK [Re: theraif] #2604779
01/11/19 03:15 AM
01/11/19 03:15 AM
SoCal
Brian Hafliger Offline
SoCal
They did an excellent job with that build!
Brian Hafliger
Re: 737 HP LA SMALL BLOCK [Re: Brian Hafliger] #2604786
01/11/19 04:32 AM
01/11/19 04:32 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
Nice, how long would that stock magnum block last?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: 737 HP LA SMALL BLOCK [Re: theraif] #2604788
01/11/19 05:09 AM
01/11/19 05:09 AM
Washington
skrews Offline
skrews  Offline
Washington
4 bolt main conversion and windage ports cut n the main webs, NO THANKS. These blocks are weak enough in that area. Makes for a good cross your fingers dyno queen. Good showing though, impressive performance.
Re: 737 HP LA SMALL BLOCK [Re: theraif] #2604818
01/11/19 11:14 AM
01/11/19 11:14 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Nice! I really like my Pro Dominator tunnel ram(converted to port EFI) but it looks like more work than I am capable of to make it work on Victor heads.
68 Barracuda Formula S 340
Re: 737 HP LA SMALL BLOCK [Re: theraif] #2604830
01/11/19 11:44 AM
01/11/19 11:44 AM
P
Porter67 Offline
Porter67  Offline
P
Ive everything to copy that with the exceptions of the heads, I wonder how that block was after going 4.100? Same intake/carbs/block.
I wonder how it would do with a 4 inch crank?
Re: 737 HP LA SMALL BLOCK [Re: Porter67] #2604835
01/11/19 11:57 AM
01/11/19 11:57 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
And more camshaft and compression. He said it would make 800 in testing spinning it higher( over 8K) .....rules limited pulls to 7500 and the motor had mufflers on it on the dyno
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: 737 HP LA SMALL BLOCK [Re: theraif] #2604842
01/11/19 12:05 PM
01/11/19 12:05 PM
P
Porter67 Offline
Porter67  Offline
P
I was just looking at that intake work done on that build, I wonder if they could of fabbed a intake vs all the work they did?
Re: 737 HP LA SMALL BLOCK [Re: Porter67] #2604858
01/11/19 12:31 PM
01/11/19 12:31 PM
Washington
madscientist Offline
Washington
If you look at that intake...for what it is it's very hard to beat. Even with the extra runner volume of the heads that plenum will still feed them, yet and the shape is nice. If you already had it on the shelf you have maybe a couple of hours of welding and the port work.
Re: 737 HP LA SMALL BLOCK [Re: theraif] #2604873
01/11/19 12:51 PM
01/11/19 12:51 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Very nice build. Makes me want to go back to a SB/4 speed for my s/s car.
Re: 737 HP LA SMALL BLOCK [Re: mopar dave] #2604921
01/11/19 01:42 PM
01/11/19 01:42 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
As most of you know these big numbers out of "dyno queens" don't really interest me because of all the tricks and costs making them one hit wonders, BUT I love seeing what the Victor heads can produce. Hopeully a set will be on my R3 block (or Ritter block) in stroker form so I can keep the RPM down and make a nice BUDGET long lasting bracket race engine. I would love to know what that block sonic checks at being a 4.100 bore.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 737 HP LA SMALL BLOCK [Re: theraif] #2604923
01/11/19 01:43 PM
01/11/19 01:43 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
can someone post links to the earlier build threads of this engine?
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: 737 HP LA SMALL BLOCK [Re: theraif] #2604976
01/11/19 03:10 PM
01/11/19 03:10 PM
Locomotion Offline
Locomotion  Offline
It's interesting to note that the engine made such good power with "only" 1 3/4" - 1 7/8" step headers! I've always felt that it's better to stay a bit conservative. However, I wonder if slightly bigger headers would have been better if the higher rpm potential of the engine was allowed within the rules.
Re: 737 HP LA SMALL BLOCK [Re: theraif] #2604999
01/11/19 04:19 PM
01/11/19 04:19 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Re: 737 HP LA SMALL BLOCK [Re: theraif] #2605003
01/11/19 04:37 PM
01/11/19 04:37 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Great. Not that I don't appreciate what it takes to accomplish that, but now, if I can run it 150-175 runs a year with just valve adjustments and oil changes, look at it over the winter and freshen it as needed, and do that for 4 or 5 years without breaking it, I would be interested.
Re: 737 HP LA SMALL BLOCK [Re: theraif] #2605011
01/11/19 04:55 PM
01/11/19 04:55 PM
P
Porter67 Offline
Porter67  Offline
P
Ya got to recall it was a contest. Not an endurance type contest.
Ya want 175 runs, build a budget bracket motor.
I sorta mistyped, id not copy that build because honestly I think with a 4 inch crank, a good set of non victor heads in a solid race block 700hp isnt extreme. My street racer is a bit over 690hp with nothing real special but it is race block based.
We just seen what the big dogs got with the victor heads, what just under 1000hp?
I wonder what that combo would of made with the exact parts but in a proper R block.
Id think your could hurt that block there without alot of effort.
Re: 737 HP LA SMALL BLOCK [Re: theraif] #2605026
01/11/19 05:29 PM
01/11/19 05:29 PM
pennsylvania
poboyengineering Offline
pennsylvania
They made some pretty heady claims about the heads.Anyone know if the #'s are legit?
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: 737 HP LA SMALL BLOCK [Re: poboyengineering] #2606146
01/13/19 09:49 PM
01/13/19 09:49 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Brett Miller has had his hand in on a couple of engines where he's started with a pro port casting. There are posts on both engines, the 59* version made just over 900HP from memory, the 48* engine, which was on display at PRI, made 1016HP
I believe this engine used the CNC ported version from Edelbrock, that they ported further.
This engine has probably got 60-70 dyno pulls on it by now, a lot can be gained in that time. I'd wonder if they tried a couple of different camshafts, along with any bolt on parts.
Alan Jones
