737 HP LA SMALL BLOCK
#2604760
01/11/19 01:39 AM
01/11/19 01:39 AM
Posts: 7,144 my own world
theraif
my own world
Let’s cut to the chase: The LA small-block racing engine we’ve been following, built by Michigan’s Valley Performance for the Race Engine Challenge, took home the gold. Based on average horsepower per cubic inch, the 376-inch underdog surprised and overpowered more than a few LS builders in the event, punching out 1.963 hp for each genuine Mopar cube and claiming the class win. https://www.hotrod.com/articles/la-engine-kicking-ls-butt-dyno/
Re: 737 HP LA SMALL BLOCK
[Re: theraif]
#2604779
01/11/19 03:15 AM
01/11/19 03:15 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
They did an excellent job with that build!
Brian Hafliger
[Re: theraif]
#2604818
01/11/19 11:14 AM
01/11/19 11:14 AM
Posts: 8,037 Tulsa OK
Bad340fish
Tulsa OK
Nice! I really like my Pro Dominator tunnel ram(converted to port EFI) but it looks like more work than I am capable of to make it work on Victor heads.
68 Barracuda Formula S 340
[Re: Porter67]
#2604835
01/11/19 11:57 AM
01/11/19 11:57 AM
Posts: 11,728 Portage,michigan
B3422W5
Portage,michigan
Ive everything to copy that with the exceptions of the heads, I wonder how that block was after going 4.100? Same intake/carbs/block.
I wonder how it would do with a 4 inch crank? And more camshaft and compression. He said it would make 800 in testing spinning it higher( over 8K) .....rules limited pulls to 7500 and the motor had mufflers on it on the dyno
[Re: Porter67]
#2604858
01/11/19 12:31 PM
01/11/19 12:31 PM
Posts: 4,457 Washington
madscientist
Washington
I was just looking at that intake work done on that build, I wonder if they could of fabbed a intake vs all the work they did? If you look at that intake...for what it is it's very hard to beat. Even with the extra runner volume of the heads that plenum will still feed them, yet and the shape is nice. If you already had it on the shelf you have maybe a couple of hours of welding and the port work.
[Re: mopar dave]
#2604921
01/11/19 01:42 PM
01/11/19 01:42 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
As most of you know these big numbers out of "dyno queens" don't really interest me because of all the tricks and costs making them one hit wonders, BUT I love seeing what the Victor heads can produce. Hopeully a set will be on my R3 block (or Ritter block) in stroker form so I can keep the RPM down and make a nice BUDGET long lasting bracket race engine. I would love to know what that block sonic checks at being a 4.100 bore.
[Re: theraif]
#2605003
01/11/19 04:37 PM
01/11/19 04:37 PM
Posts: 11,719 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Great. Not that I don't appreciate what it takes to accomplish that, but now, if I can run it 150-175 runs a year with just valve adjustments and oil changes, look at it over the winter and freshen it as needed, and do that for 4 or 5 years without breaking it, I would be interested.
[Re: theraif]
#2605026
01/11/19 05:29 PM
01/11/19 05:29 PM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
They made some pretty heady claims about the heads.Anyone know if the #'s are legit?
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
[Re: poboyengineering]
#2606146
01/13/19 09:49 PM
01/13/19 09:49 PM
Posts: 6,150 Melbourne , Australia
LA360
Brett Miller has had his hand in on a couple of engines where he's started with a pro port casting. There are posts on both engines, the 59* version made just over 900HP from memory, the 48* engine, which was on display at PRI, made 1016HP
I believe this engine used the CNC ported version from Edelbrock, that they ported further.
This engine has probably got 60-70 dyno pulls on it by now, a lot can be gained in that time. I'd wonder if they tried a couple of different camshafts, along with any bolt on parts.
Alan Jones
