removable center section of radiator yoke ?? #2603970
01/09/19 04:45 PM
01/09/19 04:45 PM
moparx Offline OP
moparx  Offline OP
for those of you that have a removable top section of the radiator yoke, how do you have the section attached ? in other words, have you just added tabs using just a couple of bolts to re-attach the top, or have you fabbed a new section to replace the one you have cut ? did you reinforce the yoke in any way ?
pics would be helpful if possible. bow
the car in question is my 69 charger, but any body style would be helpful.
TIA !
beer
Re: removable center section of radiator yoke ?? [Re: moparx] #2603993
01/09/19 05:22 PM
01/09/19 05:22 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I'll post a pic tonight. I spot welded on tabs and made a bolted connection. I also sectioned mine and added depth to the OEM piece I removed for added stiffness, and it allowed me to lower the rad while I also moved it back, 2" down and 2" back. up I'm all about lowering COG and weight balance. Rad is full of water in use, right? biggrin
I was slightly concerned because I thought I read somewhere in this area there is a stamped serial number used by authorities(?) to verity authenticity of the chassis, that I might have obliterated. Screw them.
Maybe you see what I did here. The holes are the air inlets to the under hoop air inlet scoop. The gap between the hood and front of the rad air is divided, and feeds these air inlets into the underscoop to the air cleaner.
Re: removable center section of radiator yoke ?? [Re: jcc] #2604368
01/10/19 12:27 PM
01/10/19 12:27 PM
moparx Offline OP
moparx  Offline OP
thanks ! that is about what i was thinking of. i will be adding a new radiator and an ac condenser , so i will be modifying the yoke anyway. i figured it best to do the removable top at the same time.
anyone else ?
beer
Re: removable center section of radiator yoke ?? [Re: moparx] #2604399
01/10/19 01:33 PM
01/10/19 01:33 PM
Alberta
rustbuckett68 Offline
Alberta
Have a look at a B van, they have the removable top piece. Might get some ideas.
Re: removable center section of radiator yoke ?? [Re: rustbuckett68] #2604879
01/11/19 12:58 PM
01/11/19 12:58 PM
moparx Offline OP
moparx  Offline OP
thanks for the memory jog rust ! up i completely forgot about those !
beer
