Best spark plug for edelbrock rpm head
#260406
03/21/09 12:09 AM
03/21/09 12:09 AM
Need some help from you mopar guru's. Have 440 stroked to 505 with edelbrock stage 2 ported heads from Hughes engines flowing in the 320 range.I am also running msd programable 7 series box with msd high output coil. What is the best plug for my set-up ?
Re: Best spark plug for edelbrock rpm head
#260408
03/21/09 08:45 AM
03/21/09 08:45 AM
Posts: 15,551 Norwich CT USA
moparts
Norwich CT USA
Have had good luck with the Accel ACC-0416S plugs Spark Plug, Shorty, U-Groove, Gasket Seat, 14mm Thread, .750 in. Reach, Projected Tip, Resistor, http://store.summitracing.com/partdetail.asp?part=ACC-0416S&FROM=MG
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
[Re: ahy]
#260410
03/21/09 12:53 PM
03/21/09 12:53 PM
Thanks, will check the website out. I am at 13.5 C/R. 0 deck height.
[Re: Dodgem]
#260411
03/21/09 01:01 PM
03/21/09 01:01 PM
Thanks dodgem. I am at 13.5 C/R; 0 decked, heads were milled to get the C/R and milled on intake side proportionally to line up properly. Am wandering if I should use 13 or 14 as C/R in choosing plug?
[Re: Dodgem]
#260413
03/21/09 01:54 PM
03/21/09 01:54 PM
I run 110 octain. What do you think 57s?
[Re: Dodgem]
#260415
03/21/09 08:33 PM
03/21/09 08:33 PM
Posts: 4,503 NJ
440challenger
NJ
[Re: jst19600]
#260420
02/21/10 09:02 AM
02/21/10 09:02 AM
Posts: 7,664 IN
ahy
IN
My cr is 10.2. I use the plug recommended on the Mancini website for 10:1 with projected tip. The projected tip works well with my D dish pistons. Here's a link: http://chucker54.stores.yahoo.net/ngkplugs.html
[Re: jst19600]
#260424
02/22/10 01:19 AM
02/22/10 01:19 AM
Posts: 553 DE
Ply72rr
DE
I like to run the AR series Autolite.Im going with an new 408 stroker engine with eddy aluminum heads.Does anyone know what AR39?? number i should start with having about 10.7 compression?
Autolite AR3910
