The 75 Road Runner is identical underneath, to a 73-74. Yes, a 71-72 8 3/4 will bolt right in, if you ditch the iso clamp parts and use the 72 and older shock plates and U bolts. Even better is to ditch the 75 rear springs, with their oval eyes, and put a complete rear suspension from a 71-72 B body in. That way you get stiffer front spring bushings too. The rear springs on 66-72 B bodies fit right in if you use the early spring hangers too. So you could put in HEMI springs if you want to.
