Re: 94 nv3500 crossmeber replacment?
[Re: scratchnfotraction]
#2603940
01/09/19 03:40 PM
01/09/19 03:40 PM
Posts: 2,042 colorado
savoy64
colorado
i think they are all the same---we have done auto to manual conversions and the mounts are re-used--also look at the frame and notice it is cantilevered where the mount is at---jack up the tranny--removed the 2 part mounts--push the cross member up about 1 inch and slide it out the back----sometimes it takes a little hammering----putting it back in may require a little prying down to get the bolt holes to line up....just looked at a loose crossmember--there are 2 sets of slotted holes for the tranny mount--check yours....
