Re: CPPA Slant Six to RB motor mounts for A-body
[Re: MadMopars]
#2603238
01/08/19 01:41 AM
01/08/19 01:41 AM
RapidRobert
Since you ain't gettin any love on this can you post a pic of em?
[Re: MadMopars]
#2603262
01/08/19 02:36 AM
01/08/19 02:36 AM
Posts: 1,293 Tucson AZ,
MadMopars
Tucson AZ,
Since I dug them out for a picture, I just went ahead and figured out the mounting. Looks like they just bolt to the two front lugs on the block only. Additionally, utilizing them with a high volume oil pump looks to be less optimal as they will require some work to clear the oil pump cover. I'm sure they'll work out, just going to need some loving if I had to guess. I'll post up some mock up pics when I get more time and report back. At this point, I'd be curious to see how some of the other conversion mounts fit. -Trent
[Re: JAMESDART]
#2603702
01/09/19 01:23 AM
01/09/19 01:23 AM
RapidRobert
iirc we used schumaker mts on a /6 to 383 in a 69 valiant. Perfect fit.
[Re: JAMESDART]
#2603704
01/09/19 01:29 AM
01/09/19 01:29 AM
MadMopars
Tucson AZ,
Tough crowd. In all fairness, I'm not even sure there were any other conversion mounts on the market when these were purchased. I'm thinking it was sometime around 1996. In any case, I've also got the 2" CPPA under chassis headers so I'm hopeful everything will fit together nicely. I'm not saying the mounts are flawless but I think with a few tweaks, they'll be alright. I'm hoping I can mock up the K frame to the block soon and check fitment on a couple items before long. I have some concerns about the Milodon deep pan clearing the steering so I'm kind of anxious to see how it looks. I'll let you guys know how it goes and post up some pics when I get around to it. -Trent
