When you rewired your race car did you. #2602423
01/06/19 02:36 PM
01/06/19 02:36 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
Change out all of the one gauges for aftermarket??
I'm in process of rewiring my 68 barracuda,
I would like to reuse the original gauge set (as well as add a performance gauges). It is a pet peeve of mine to have inoperable gauges in the dash.
Has anyone done this with an aftermarket harness???
I am using an American autowire universal harness.
Looking for a little help on how to do this.
Re: When you rewired your race car did you. [Re: 8urvette] #2602433
01/06/19 02:55 PM
01/06/19 02:55 PM
moparx Offline
moparx  Offline
a FSM will be a valuable tool to see how the circuits are wired. [or use the site [alpar maybe ?] that hosts wiring diagrams.]
the amp gauge should be ditched, but you may be able to change that up to a volt gauge conversion in the factory amp gauge location.
the oil, water, and gas gauge need a 5v signal, so keep the can you have now that converts 12v to 5, or get a new, electronic one.
just make up a mini harness [if needed] for your original gauges, and attach that to an accessory point on your universal harness.
sounds a lot more complicated than it actually is.
beer
Re: When you rewired your race car did you. [Re: moparx] #2602485
01/06/19 04:45 PM
01/06/19 04:45 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I would never re-use the OEM gauges as many of the stuff can be in accurate or tough to read or short out and cause a fire.....
Which is why I like wht these guys offer...
https://classicdash.com/product/1967-69-barracuda-6-gauge-panel-with-auto-meter-gauges/
Re: When you rewired your race car did you. [Re: 8urvette] #2602489
01/06/19 04:53 PM
01/06/19 04:53 PM
AndyF Offline
AndyF  Offline
You can send your original dash to someone like Redline Gauge if you need to have it repaired. Redline can also customize the factory dash panel to change the ammeter to a voltmeter and stuff like that.
https://redlinegaugeworks.com/
Re: When you rewired your race car did you. [Re: AndyF] #2602526
01/06/19 06:29 PM
01/06/19 06:29 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
For the money I'm going to ditch the factory stuff and go with a Holley EFI dash. They are able to work in a stand alone mode. After fighting with four plus cars at a time worth of Mopar gauges for 20+ years has me a little downtrodden from removing the clusters so many times. If it's not a bouncy speedo it's a dead fuel gauge. I've had factory 5v regulators outlast the solid state models that come in the new style circuit boards too. Very irritating as you usually have to drop the steering column to work on it. Don't even get me started on the electroluminescent problems in (especially) my '66 Chargers. The harder the car is driven the more problems I have had. I could be unlucky, that's for sure!
Re: When you rewired your race car did you. [Re: 8urvette] #2602813
01/07/19 10:21 AM
01/07/19 10:21 AM
Bowling Green KY / Nashville, ...
300by500 Offline
300by500  Offline
Here's what I did to my '69. Good ideas from others in the thread, too.
https://board.moparts.org/ubbthreads/ubbt...acuda-dash.html
I can't believe this was over 10 years ago! I seriously need to drag the Barracuda out of the corner of the garage and finish it...
Re: When you rewired your race car did you. [Re: 8urvette] #2602819
01/07/19 10:48 AM
01/07/19 10:48 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Racecar or street car? Racecar I removed the factory gauges. Replaced them with in dash aftermarket. Used 1/8"aluminum plate in place of the stock cluster. Stock bezel screed to the plate.
Doug
Re: When you rewired your race car did you. [Re: dvw] #2602840
01/07/19 12:00 PM
01/07/19 12:00 PM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
grin
Re: When you rewired your race car did you. [Re: 300by500] #2602849
01/07/19 12:23 PM
01/07/19 12:23 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I did something similar with my 68, except the tach and speedo fit in from the backside.
68 Barracuda Formula S 340
Re: When you rewired your race car did you. [Re: LAD 524] #2602892
01/07/19 01:26 PM
01/07/19 01:26 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Originally Posted By LAD 524
grin
How come the gauges don't rotate counter clockwise? work biggrin
Re: When you rewired your race car did you. [Re: jcc] #2602914
01/07/19 02:08 PM
01/07/19 02:08 PM
moparx Offline
moparx  Offline
grin
you mean like this ? biggrin
beer
