68 vin vs body I D numbers #2602003
01/05/19 06:33 PM
01/05/19 06:33 PM
fresno ca
mikeysmopars Offline OP
fresno ca
Question for the guru's regarding 68 vin numbers and rear trunk lip numbers. I'm building a 68 Coronet for my kid and was curious how anyone can tell from the VIN weather how body ID number matches the rear trunk lip, I know 69 n up the vin matches that numbers but 68 and back doesn't?
Founder and CEO of the Central Valley Mopar Drag Pack
Re: 68 vin vs body I D numbers [Re: mikeysmopars] #2602015
01/05/19 06:56 PM
01/05/19 06:56 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
You would need original paperwork like a broadcast sheet, factory to dealership invoice or Mulroney label as a few examples to tie the two numbers together.
Re: 68 vin vs body I D numbers [Re: Alaskan_TA] #2602257
01/06/19 12:07 AM
01/06/19 12:07 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
If you can tell the fender tag has never been off then that is all you need. Paperwork always helps... work
JB Rhinehart, Realist
A-Body's RULE!
Re: 68 vin vs body I D numbers [Re: Alaskan_TA] #2602331
01/06/19 04:41 AM
01/06/19 04:41 AM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
Originally Posted By Alaskan_TA
You would need original paperwork like a broadcast sheet, factory to dealership invoice or Monroney label as a few examples to tie the two numbers together.
And the lower right of an original fender tag....as Jim said wink
Re: 68 vin vs body I D numbers [Re: mikeysmopars] #2602380
01/06/19 12:44 PM
01/06/19 12:44 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The '68 fender tags have the SO number & it would match the body numbers, not the dash VIN.
Thus, original paperwork would still be needed to tie the VIN & body numbers together.
Re: 68 vin vs body I D numbers [Re: mikeysmopars] #2602480
01/06/19 04:37 PM
01/06/19 04:37 PM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
Vin tag, fender tag and body numbers ties the car together, Certicard would also help. I believe 68 and older cars, the fender tag is more important than the vin tag but of coarse you need the vin tag.
Build sheet!!!
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
Re: 68 vin vs body I D numbers [Re: mikeysmopars] #2602918
01/07/19 02:21 PM
01/07/19 02:21 PM
fresno ca
fresno ca
I don't have the fender tag or build sheet🙄. It's just a 318 auto car but was curious on the 68 and back cars why the body numbers weren even close to the VIN.
Thanks for the help, if the fender tag surfaces I'll chime back in.
Re: 68 vin vs body I D numbers [Re: mikeysmopars] #2602949
01/07/19 02:51 PM
01/07/19 02:51 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The numbers stamped into on the bodies of pre 1969 cars were the vehicle order and line number, not the VIN sequence numbers.
Re: 68 vin vs body I D numbers [Re: mikeysmopars] #2603991
01/09/19 05:20 PM
01/09/19 05:20 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Your body is stamped
E - Los Angeles
8 - 1968
W - Coronet
094485 - Order Number
The order number is on the fender tag, build sheet and Window Sticker also.
The build sheet and Window Sticker are the only thing that ties to the two numbers together.
