truck problems dies randomly #2602465
01/06/19 04:12 PM
01/06/19 04:12 PM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
92 dakota,ive owned it for nearly 27 yrs!!
it developed a problem that caused it to randomly die,it always restarted ,so ive replaced the ign switch,the crank position sensor,it seemed to be ok,then it did it again,i have to turn the key completely off and recrank to get it to start,so today i checked fuel pressure which was ok,i drove it around about 15-20 miles and of course it was ok!!!,i looked at the wiring harness connection that dakotas were famous for a long time back and it was ok,so...im wondering if a bad throttle position sensor could cause my problem?,ive actually seen this truck run with the cam position sensor unhooked after it was started so i have doubts that is the problem,id rather not load up the parts cannon!!,no check engine light,anyone got any ideas???,its got lots of miles on it kinda like me,but is my favorite truck!!
my ladder of success is missing some rungs
Re: truck problems dies randomly [Re: rhad] #2602651
01/06/19 11:09 PM
01/06/19 11:09 PM
Brookville Pa
crowbait Offline
crowbait  Offline
Brookville Pa
Maybe fuel pump. Our 06 Durango would randomly shutoff idling around parking lots and the like on and off for a couple years. Put a fuel pump in it and was fixed. Anytime I checked fuel pressure in this thing it showed ok.
Re: truck problems dies randomly [Re: crowbait] #2603723
01/09/19 02:08 AM
01/09/19 02:08 AM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
well?
it died on me once yesterday and once today,no sputtering ,it just dies,like someone shut it off,i have to cycle the key off and back to crank to get it to restart,im thinking a bad connection in the wiring somewhere??
Re: truck problems dies randomly [Re: rhad] #2603763
01/09/19 03:40 AM
01/09/19 03:40 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Got a good battery in that Dakota?
Re: truck problems dies randomly [Re: rhad] #2604259
01/10/19 02:10 AM
01/10/19 02:10 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Check the grounds. Then check again.
Then one day you’ll find the broken wire.
I want my fair share
