Re: alcohol vs race gas [Re: ek3] #2602030
01/05/19 07:34 PM
01/05/19 07:34 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Bearing wear being different on e85 would only be from 2 things. Detonation/tune, or oil dilution from tune as well.
Re: alcohol vs race gas [Re: ek3] #2602246
01/05/19 11:42 PM
01/05/19 11:42 PM
georgia
intenseneon Offline
intenseneon  Offline
georgia
On my 12:1, solid cam 408 I made 50hp and about the same more in tourque with Alky over 110 fuel.
69 Dart
Re: alcohol vs race gas [Re: dthemi] #2602252
01/06/19 12:02 AM
01/06/19 12:02 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: alcohol vs race gas [Re: ek3] #2602757
01/07/19 02:33 AM
01/07/19 02:33 AM
Mark Whitener Offline
Gains depends on the Induction and combustion efficiency of the engine, and how well the converter and gear are matched to go with it. I just had a customer switch from a 650 on gas to a 650 on methanol and pick up 1/2 a second in the 1/8 mile. My SB2 head engine in my dragster would slow down with anything other than gas (no nitro in this conversation...;-) ) So it's really subjective to the combination.
Mark Whitener
[url=www.racingfuelsystems.com[/url]
Re: alcohol vs race gas [Re: ek3] #2603444
01/08/19 03:11 PM
01/08/19 03:11 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
I suppose the best way to illustrate the situation with alcohol is an example.
Take any NA engine in the world, injected, or carbureted. Give unlimited resources to modify for maximum performance, and in no case will alcohol, out perform gasoline.
The reduced energy in alcohol, as compared to gas will always prevent it from reaching the efficiency of gasoline.
Re: alcohol vs race gas [Re: ek3] #2603449
01/08/19 03:18 PM
01/08/19 03:18 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
There is an example of gas exchange in the lungs that is appropriate for this as well.
Think of the available space in the induction tract as seats on a bus. When the bus pulls up to the stop, and people get on, in this case fuel atoms, only so many can climb aboard. The bus is going to a job site, where the strength of the people filling the seats is critical to the amount of work that can be done. People twice as powerful do twice the work, when you can only haul so many at a time to the job site.
Re: alcohol vs race gas [Re: ek3] #2603486
01/08/19 04:46 PM
01/08/19 04:46 PM
an8sec70cuda Offline
I help a friend w/ his Camaro. 436" sbc, 14.5:1 compression, AFR heads, glide, 9", ladder bars, etc. Makes somewhere around 700 hp.
Ran on alcohol (4150 Demon 825 cfm carb) and ran a best of 5.78 in the 1/8 mile w/ a 1.24 sixty foot at 2900 lbs. Ran this configuration for years.
Switched it to race gas a few years ago (112) and went to a 1050 Dominator...same manifold (Edelbrock Victor 4150) w/ the tall 4500 adapter. Now it's 100 lbs heavier at 3000 lbs and it went a best of 5.93 w/ a 1.27 sixty foot. It lost a noticeable amount of lowend torque and obviously some HP, but never dyno'd either setup.
Knew it would slow down some, but was hoping the Dominator would help not to slow down too much. It has more in it (still needs more tuning), been a long time since the car was run, but it won't run what it did on the alcohol.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: alcohol vs race gas [Re: an8sec70cuda] #2603494
01/08/19 05:08 PM
01/08/19 05:08 PM
My personnel opinion on straight methanol, not race methanol like M1 or M5, is it will as fast or faster by a tiny bit on straight methanol compare to non oxygeneated race gas twocents
I switch to pump E 85 several years back and love it, deadly consistent and half as much cost per gallon as the local race gas and the motor runs cooler boogie up No issues with oil dilution either up
Re: alcohol vs race gas [Re: Cab_Burge] #2603766
01/09/19 04:03 AM
01/09/19 04:03 AM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline OP
ek3  Offline OP
E
Originally Posted By Cab_Burge
My personnel opinion om straight methanol, not race methanol like M1 or M5, is it will as fast or faster by a tiny bit on straight methanol compare to non oxygeneated race gas twocents
cab, don't you burn about twice as much alky as you would gas ? wouldn't that make alky about the same cost as gas ?
stirthepot
Re: alcohol vs race gas [Re: ek3] #2603780
01/09/19 05:49 AM
01/09/19 05:49 AM
E85 is suppose to burn 30% more, I think straight industrial methanol may be close to 80 to 90% more than race gas but it is a bunch cheaper per gallon and runs a lot cooler, it also burns a lot slower in the cylinders so it pushes down on the pistons quite a bit longer also up shruggy
The one bad side of straight methanol that I'm aware of is the oil dilution due to methanol sucking moisture out of the air and having it condense inside the cylinders also as well as in the oil puke
Re: alcohol vs race gas [Re: ek3] #2604121
01/09/19 09:59 PM
01/09/19 09:59 PM
gregsdart Offline
gregsdart  Offline
There are some inaccuracies posted so far.
Methanol burns slightly faster than gas. I run 34 degrees timing on alky, a lot of 440-1 motors on gas run more.
Methanol has more energy than gas based on a stoiciometric mixture, because it runs at least 2.2 times the volume of fuel per cfm of air than gas.
The fact that some claim gas makes more power may well be that only very high rpms allow this? The statement flys in the face of thousands of racers seeing reduced ETs going to methanol.
Methanol lowers charge temp considerably, increasing the amount of air (measured as mass) inhaled
Re: alcohol vs race gas [Re: ek3] #2604384
01/10/19 12:55 PM
01/10/19 12:55 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
The reasons some motors make more power on alky are mostly based in the inefficiencies inherent in the type of motor. No one is arguing that almost all bracket type engines will behave better on alky for bracket racing.
The decrease in timing requirement in a few motors isn't related to the fuel being better, but the increase in chamber efficiency brought about by twice the volume of liquid in the chamber, and how that effects compression. Also the reduction in temperature.
The effort required to deliver twice the volume of fuel, and the space that it consumes in doing so will always handicap the process in high efficiency engines. A normal 1.8hp per inch bracket motor would almost always be helped by alcohol. A 3hp per inch gas motor would be crippled by alky.
It really just comes down to the energy density of fuel.
Fuel Density
kg/m3kg/m^{3}kg/m​3​​ Specific Energy
MJ/kgMJ/kgMJ/kg Energy Density
MJ/m3MJ/m^{3}MJ/m​3​​
Gasoline 716 -47.3 -33,867
Kerosene 830 -46.2 -38,346
Diesel Fuel 830 -44.8 -37,184
Ethanol 784 -29.7 -23,278
Coal (Anthracite) 1350 -27 -36,450
Methanol 787 -22.7 -17,855
Wood 600 -15 -9,000
Coal (Lignite) 801 -15 -12,015
Re: alcohol vs race gas [Re: dthemi] #2604512
01/10/19 05:22 PM
01/10/19 05:22 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
We made 18 hp more with q16 over pump e85..back to back .the e85 carb was a little bigger shruggy
Re: alcohol vs race gas [Re: WHITEDART] #2604521
01/10/19 05:33 PM
01/10/19 05:33 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
How much was the Q16 a gallon?
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: alcohol vs race gas [Re: pittsburghracer] #2604527
01/10/19 05:44 PM
01/10/19 05:44 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
. $20 a gallon.. vs E85 at $3.. personally I loved E85 just couldn't make it happy where we were at even experimented with race blend E85 at $20 a gallon
. I will tell you my valve spring bill offset the cost in the fuel for sure.. we like to leave the starting line absolutely as cold as possible on cue and used to like to leave the starting line at 180 degrees on the E . Which was definitely hard on the valve springs and valve job
Re: alcohol vs race gas [Re: ek3] #2604797
01/11/19 08:46 AM
01/11/19 08:46 AM
Mo.
racerx Offline
racerx  Offline
Mo.
were there a HP difference with the race blend e-85?
Re: alcohol vs race gas [Re: racerx] #2605128
01/11/19 09:27 PM
01/11/19 09:27 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
were there a HP difference with the race blend e-85? [/quote] . Unfortunately only tested in the car never on the dyno and personally didn't see much to gain with our application
Re: alcohol vs race gas [Re: WHITEDART] #2605133
01/11/19 09:44 PM
01/11/19 09:44 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
. Unfortunately only tested in the car never on the dyno and personally didn't see much to gain with our application [/quote]
That "goofy" e-85 you had made Q16 smell good. It should have come with a Hazmat suit
"Just a Bracket car dressed up like a streetcar"
Re: alcohol vs race gas [Re: WHITEDART] #2605291
01/12/19 04:39 AM
01/12/19 04:39 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Thaxs……. I kind of wonder if there were an real world advantage of using the race blend verse mixing your own.
Re: alcohol vs race gas [Re: ek3] #2605330
01/12/19 11:46 AM
01/12/19 11:46 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
VP C85 makes more power than pump by a couple percent. Due mostly to MTBE, and some other unsavory chemicals. One of which I think is one of the propane family.
Smells terrible, but works better on higher compression ratios. Stays consistent, and has the best corrosion inhibitor I've ever used in an alcohol fuel.
